Question about Panasonic Home Theater System System
System Says hello, then says INIT
Radio does't work, cd's won't eject, nothing but INIT
    Scholar:
  • 107 Answers
You might have 2 problem
Power supply regulator, electrolytics capacitors dried out in power supply block or DVD Ram defective or both depend your area or contry some of DVD Ram is NLA at Panasonic like Australia
However you need a qualifier Tech to check the unit if the power supply is worth to repair it if DVD Ram or both is not worth to repair it
Posted on Dec 07, 2008
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Hi, My panasonic SA-HT940 IT IS READING INIT WHAT DOES THAT MEAN.??
check system output by aux port if output is normal then system amplification work proper
try another cd all cd it reading or init then lense clean with lense cleaner and try
May 18, 2012 | Panasonic Home Theater System System
Hello, I have had a CD stuck in my Clarion DB345MP car stereo, when I press eject, I listen a noise but nothing happen. The radio is fine. Somebody help me.
the cd mechanism itself is probably bad and needs to be replaced. not ejecting is a common problem with that model of radio.
Jan 15, 2011 | Clarion DB345MP AM/FM CD/MP3 player
I cannot get the CD player to eject the CD. the radio is a standard AM/FM radio with a CD player in a 2005 Ford explorer XLT. after pushing the eject button the radio screen blinks ''EJ err''. The cd...
Turn the radio off first and then disconnect the battery for 2 min then reconnect the battery. This should reset your radio and then you can eject your CD, and reset your stations and clock. Good luck
Sep 30, 2009 | 2005 Ford Explorer
The player will not eject the cd but it will not play it either.
I know it sound crazy, but turn the system on, press eject while using a PLASTIC knife to lift the CD in the player. If the system is stock also try disconnecting the radio fuse for about 10 minutes or so with the car off. Reconnect it to see if the radio resets. You'll know the power completely went out because you'll have to reset your stations. By Resetting, hopefully the issue will solve itself. In a few of the system issues I've seen, when the motor won't open the faceplate, or the CD player won't give the CD back. I usually remove the faceplate or disconnect the negative side of the battery for about ten minutes. Try this if the fuse removal doesn't work. Good look. Let me know how it goes. there are other things to try.
Jul 27, 2009 | 2004 Honda Pilot
CD IS NOT ABLE TO BE REMOVED. IT'S LOCKED IN THE CD COMPARTMENT
get a butter knife and force the cd tray to open try not to force to hard that it breaks but enough that it might kick in the eject by itself
Apr 11, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
Error e-20. Doesn´t Work anything related to the Cd Players.
The system may need to reset. Unplugged the amp from the power source completely and let it rest for at least 5 minutes.
The illumination can only be controlled from the main remote. Adjust the prongs inside the remote and this should fix the issue.
Jul 28, 2007 | Nakamichi SoundSpace 9 CD Shelf System
Panasonic Home Theater System System Logo
291 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
