Question about Kenmore 62602 Electric Dryer
My kenmore electric dryer front loader model # 110.8756 is not drying at all. Air is coming out and the electricals and vent are working fine. It is blowing out cold air.
It may be the thermostat on the heating element. There are two on the side of the element, and one on the left side near the vent return. . If any one of these goes bad the drying will stop. I replaced each one at a time and the very last one I replaced was the one that was bad. Now I am back in business (laundry that is). I replaced the thermostates and my drying starting drying the clothes better than before. Try this before replacing the element, it is much cheaper (only $39.00) than replacing the element. FYI, they will check these thermostates at your parts store for you for free if you ask. . Women's Lib!! I fixed it myself. Good Luck, Kathy in SC
Posted on Jan 07, 2009
  • 25 Answers
Heating element needs to be replaced
Posted on Dec 07, 2008
3 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Posted on Jan 15, 2009
heatman101
  • 43501 Answers
SOURCE: The air drying the clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 04, 2010
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
I have a Kenmore electric drier # 110.60912990 It runs fine, but no hot air. What should I check. I checked the outside vent and air is coming out. I check the circut breaker and it is fine.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Kenmore 64942 Electric Dryer
Dryer stopped working as it was drying, was real hot and will not start now. Kenmore 80 series electric
Problem common with blocked vent, need to check house vent...dryer has blown the thermal fuse. found behind the back panel small white fuse(usual two blue wires)....clear the vent and replaced the fuse. run on air dry first to check vent, should feel close to a hair dryer on low.
Jun 10, 2009 | Kenmore Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Won't dry clothes
Try running the dryer with the vent pipe unplugged. There should be a lot of hot air coming out, if not the insides need to be cleaned. If it really moves air, and dries a load ok unhooked, your vent is clogged. Clean it if you can. If you can't, look into a lint trap that will work for your situation, some have a water trap, some are good filters, etc. If the air is not hot, some of the electric element may be bad. If it's gas, it could need a tune up and cleaning inside.
Apr 24, 2009 | Kenmore Dryers
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Water in vent
your vent out the house is broke or fell off,,suspose to a flap or lilltle blind type,,the cold air is coming in whule the hot air is trying to get out and it condensates in the vent hose ,,replace out side vent..with new vent kit..the best by is window ehaust kit...onthejob
Jan 10, 2009 | Kenmore 82822 Electric Dryer
Dryer does not turn anymore, dried shoes inside
the belt that turns the drum has broken or come off
you will need to remove the housing and replace the belt or call for service
Good luck
Jan 07, 2009 | Kenmore 62602 Electric Dryer
Clothes Dryer not drying
Hello, check to make sure that the dryer is venting properly, is the hot air getting out of the vent ?. If not clear the restriction or unkink the vent then try again. good luck
Dec 16, 2008 | Hotpoint NVL333EY Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Kenmore 62602 Electric Dryer Logo
163 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
