Question about AAD C-600i Main / Stereo Speaker
Amp or speaker problem
I have 7.1 preamp/ amp combo that is losing a channel after it warms up. I'm using Infinity beta 50 speakers the amp combo is Outlaw. Prior to the Infinity speakers I was using Rectilinear III speakers. The problem happened with both brands. Originally I thought that front left channel was problem. When the channel cut off I switched to one of the rear surround channels. It worked great for about 15 hours total play time. Then same thing, so I switched agian. Worked great for about same amount of time. I've already ruled out speaker cables and interconnects, all good. I know it sounds like speaker problem, but it happened on both brands. Any ideas?
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: Stereo speaker suddenly stopped giving sound
You will need to take the speaker apart and with an ohm meter or continuity tester, measure the resistance of the speaker right at the speaker to see if the speaker is open. if it is you have no choice then to replace the speaker. If the speaker measures a low resistance, measure the wires froom the speaker to the output wires or terminals. Some speaker manufacturers install small fuses inside their speakers. Good Luck
Posted on Mar 29, 2007
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
What wattage&ohmage of speaker is best
Hello
Your amp has an output power of 50 Watts per channel into 4 Ohms speaker. It is designed to work with 4 Ohms speakers, and it will be best to slect 4Ohms impedence speakers to connect with this amp. Consider the Watts capacity of speaker too. It must be not less than 50Watts. In short, you have to select 4Ohms speakers, haveing more than 50Watts power handiling capacity. Remember, as Watt capacity of speaker increses, the cost will also increase considerably. OK.
Jan 19, 2012 | Teac A-H300 Amplifier
I OWN A NAD M 25 ---7 CHANNEL AMPLIFIER. I AM USING 4 CHANNELS TO BIAMP MY SPEAKERS. ONE OF THE UNUSED CHANNEL IS SHOWING A RED PROTECTION LIGHT.THE BIAMPED CHANNELS ALL WORK FINE ...I HAVE CHECKED ALL...
The manual would suggest you have a problem.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-M25-Amps-manual/id/8043ci561/t/2/
Try unplugging all of the speakers and see if that amp is still distressed. If it looks clean and happy start adding speakers until it returns (or not).
Jul 03, 2011 | NAD M25 Amplifier
I have 2 Sonance Sonamp 260's and I want to bridge them to run two different channels. Although I am not sure on how to do this. I am using my Carver HR-742 and I will be powering 2 Infinity SM-155's. I...
http://www.retrevo.com/search?q=Sonance+Sonamp+260
It's not bridgeable according to the manual.
Who specs an amp at 3 ohms anyway? Your Carver might be just as effectively powerful.
May 01, 2011 | Sonance Sonamp 260 MKII 2-Channel...
Only two of my speaker channel's work when I hook my speakers into it, and one of those two only powers some of the speakers in my Infinity Beta 50. The surround sound channels do not work either. only the...
You have to configure it first. Make sure you follow the instructions on page 5 of your manual to run Auto MCACC Setup which tests the acoustics of your room, speaker size, power level, etc. This is necessary before it will enable you to use surround sound.
Apr 13, 2011 | Pioneer VSX-72TXV Receiver
Yamaha m70 amp and c70 pre-amp right speaker stopped working
First, lets's determine if it's the amp or the preamp...
Swap the Left and Right channel cables between preamp and the amp with each other.
Did it stay on the right? = amp problem.
Now on the left? Preamp or source.
Plug any Line Level device (CD?) directly into the amp inputs. Work now? Preamp problem.
ALL sources? Preamp - toggle all controls, especially a Tape Monitor to possibly wipe of any built-up oxides in them.
May 31, 2010 | Audio Players & Recorders
Amplification
You need to now the RMS for a true capacity of your speakers and your amp.
I would say you are OK, with a margin, but if you turn the amp to max and blow the speakers, please dont call me.
Sep 30, 2009 | Sunfire Cinema Grand Signature 400 seven...
Big POP from speakers when powering on.
look for any cold solder or component terminal lose contacts at the solder side of the P.C.B. particularly at the tone control preamplifier stages and power amp stages, if you find some lose contacts re-solder it...it might solve your problem...
"WARNING" avoid short solders...
Mar 19, 2009 | Marantz Audio Players & Recorders
Component speaker not working
The easiest thing to test is to try swapping the connections of the front component speakers at the amp connections. If the problem follows the speakers, the issue is probably with the speakers. I would triple check (again) the speaker wire connections. It's also possible the crossover for the driver side component speakers has an issue (thus why the tweeter worked for a while).
If the problem stays on the drivers side, the issue is probably with that channel on the amp. Triple check the RCA connections for that channel.
It's much easier to test other speakers on an amp channel versus trying to check it with a meter.
If the driver's door is "abused" often, my initial thought is the wiring at the speaker or the wiring in the speaker (to voice coil, within the crossover, etc) is the most likely culprit.
Apr 10, 2008 | Infinity 475A Car Audio Amplifier
Blown channel?
your amp try to protect itself from damage when he feels some trouble from your sub.-start by changing sub cabel and sub itself if it does not becomes ok.
if all above failed---you have serious problem in sub output stage and can be fixed in service center.
Oct 17, 2007 | Audio Players & Recorders
AAD C-600i Main / Stereo Speaker Logo
Top AAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an AAD Audio Player and Recorder Expert? Answer questions, earn points and help others
