Question about Dishwashers
Washing light flashes a short time after starting a cycle on a Kenmore Dishwasher model number 587.15182400
Problem was the live side contact on the door switch, with the door shut the neutral side (white wires) were shorted but the live side (black wires) were open. I removed the complete module and discovered that the actual contacts were removable, lift a single catch and slide out. Contacts were cleaned with abrasive and now all is OK. However, this is a short term fix only, already damaged contacts will continue to degrade and give trouble. Does anybody know if the contacts can be purchased or do you have to buy the complete door latch module?
Tim
Posted on Dec 07, 2008
Dishwasher wont finish any cycles
That blinking light is trying to tell you that there is something wrong with the dishwasher. You need to fix the problem or else that blinking light will come back. And the number of times it blinks (before it pauses and repeats) will tell you (or a technician) what is wrong. How many times does it blink?
Jul 04, 2014 | Kenmore Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite model 16574
press (high temp-wash) button and then ( heated dry)
do that 3 times in that order within 5 seconds. So it looks like this:
(high temp-wash) ( heated dry) (high temp-wash) ( heated dry) (high temp-wash) ( heated dry)
That will start a short diagnostic cycle (last about 2 minutes) that will clear the blinking light and allow you to use the dishwasher. If the light comes back, your drying cycle has failed and you will need service.
Oct 28, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Kenmore dishwasher blinking light
I have a solution. For Kenmore Dishwashers begining with model 587 and the flashing washing light.it will not start.
inside the front door there are two black and two white wires that lead to the handle. this connection is an on/off saftey for the door latch and if wet will short. The light is flashing because the machine thinks the door is open.
these connections on my machine are very loose. a needle nose pliers to tighten the crimps clean the prongs recconect hard reset at breaker box and you should be ready to go.
m
Feb 01, 2008 | Dishwashers
Two Green Lights Flash Mid Cycle.
It's possible that there's a fault in the drying heater coil, but I couldn't tell you for sure without looking up your machine. If you could locate the model number tag on your machine and write down the exact model number and serial number, then I could likely give you a more informative answer. ;)
Aug 08, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
135 people viewed this question
Top Dishwashers Experts
