Question about Linksys WRT300N Wireless Router
Im trying to hook up my router to the cable modem what do i do
  • 83 Answers
SOURCE: I have a linksys wrt54g router. Lost power the
Check to make sure that your route has DHCP turned on.  Save your settings and turn everything off.  Power on you modem and wait at least one minute, if your modem has a link light, it should come on and stay solid once it connect with your ISP.  Then turn on your router and wait another minute for it to sync with your cable modem.  Finally, turn on your computer.  Remember that everytime that you plug something new into your cable modem, you have to reset your power.
Posted on May 03, 2009
SOURCE: We just bought a Linksys WRT54G2 Wireless-G
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 05, 2009
chocoberry
  • 94 Answers
SOURCE: Mu WRT150N Router appears to have stopped working.
When connecting the devices make sure that you turn on the device in this manner: modem (wait for the lights to be solid) then router, then the computer.
Check if you can get online, if not then follow the steps below:
1. Open a web browser and type this in the address bar: 192.168.1.1
2. Then you will be in the setup page of the router. You need to know what is your connection type obtained from your ISP.
If DHCP, internet connection type should be: Automatic Configuration - DHCP should be selected.
If PPPoE, select PPPoE and type the username and password provided by your ISP.
3. Then save the changes.
Once that the internet connection is working from the PC hardwired connected to the router, then check the wireless settings under the wireless tab. Take note of the SSID, wide channel, and the wireless security and preshared key.
Put those settings on the wireless adapter of the laptop and you should be able to get online.
I hope this works! Good luck!
Posted on Dec 15, 2009
rmoseng
  • 77 Answers
SOURCE: When I have my lynksys wireless router hooked up
Guru - Marked is correct but may I add this:
 The WRT160N router has short memory to be used by torrent / emule. If you start using many seeds/connections then this router cannot manage them all and stops working. You can try to  reduce the maximum connections in emule, in the routers settings.
Before you reset your router I would recommend making sure you have the latest firmware upgrade, as follows:
Follow these steps to upgrade the firmware on the router : - Open
an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password type admin in lower case...
Click on the 'Administration' tab- Then click on the 'Firmware Upgrade' sub tab- Here click on 'Browse' and browse the .bin(firmware file) and click on "Upgrade"-Wait for few seconds until it shows that "Upgrade is successful" After the firmware upgrade, click on "Reboot" and you will be returned back to the same page OR it will say "Page cannot be displayed".
If so, then, press and hold the reset button for 30 seconds.
Then, unplug the power keep holding down the reset button for
another 30 Seconds.
Plug back the power back in, and keep holding down the reset button
for 30 Seconds.
Release the reset button.
Here is the link to the latest firmware for this router:
http://www.linksysbycisco.com/US/en/support/WRT160N/download
Good Luck
Posted on Dec 30, 2009
Can i hook up wrt120n to laptop without hooking up to cable modem to fix?
Try this: Unplug EVERYTHING(related to both the router and modem). BEFORE you plug in power to anything, connect all of your ethernet. So, first ethernet goes from modem to router. Make sure they are in their proper places. Next, take another ethernet cable and attach that from modem to computer. NOW, power everything up. Google the linksys router splash page login. Im sure it'll be something like: 192.168.1.1 or 192.168.0.1 or something along those lines. From there, you should be able to set up your wireless. Once thats all good, unplug just your computer and everything should be fine. If that doesn't work, its either time for a new router or you're having wifi card issues.
Apr 28, 2012 | Linksys WRT120N Router
I did what the direction said and im not on the internet what can i do
Make sure that you have the cables hooked up correctly. The ethernet cable going from your modem should be connected to the port labeled WAN or Internet on the back of the router. Also, make sure to unplug the modem for 30 seconds, and plug it back in. This will clear out any MAC addresses that the modem has stored. If this doesn't work, try resetting the modem and starting over. unless you are trying to set up a wifi password, there should be no setup necessary for wireless routers.
Mar 02, 2011 | NetGear WNR1000 Router
Im trying to hook up a router to this modem so i can plug in multiple internet connections but the router needs a phone line to be plugged in but do not know how. Any help?
hello, im confused here, have you a cable modem or telephone line. if you have a cable modem then you plug an ethernet lead rj-45 from your modem to your router.but if you've a telephone line then you have to connect a filter to you telephone box an a rj-11 lead from your filter to your router hope it helps
regards
shaun
Nov 28, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Cant hook up xbox 360 to internet
does this help it sounds like you are puting your cable in to the 360 and the modem you wont have a internet ligth on untill you try to connect the 360 to go live you must reset the modem
Jan 23, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Im haveing a problum hooking it in
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
Apr 07, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
Linksys WRT300N Wireless Router Logo
20 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
