Question about Apple iPod classic MP3 Player
My ipod is not charging via laptop with new battery installed it reaches 500 or so songs and says error code -124 not sure what to do thanks for any advice i have the ipod 80g white 5th gen
  • nick_1973 Dec 07, 2008
    my usb is 1.1, i have done the restore and tried again however after the 500 song and a new battery in my ipod it still says eror 124 and that summit to do with harddrive not copying all the songs so when i charged it agin it only had about 7 songs on the pod, is restore the same as formating the ipod?
    Genius:
  • 1,061 Answers
Format it and reinstall/sync with itunes.your folders have been corrupted some how.RICHARDM69
Posted on Dec 07, 2008
Ipod will not turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod.
When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge.
iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes.
If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Sep 08, 2013 | Apple iPod Audio Players & Recorders
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
Ipod does not power up
Mar 24, 2013 | Apple iPod Audio Players & Recorders
My new ipod shows low battery how do i charge? via laptop?
If you have not already done so, install the software on your laptop which came with your ipod.
With your new ipod there will be a USB cable, simply plug that into a USB port found at the side of your laptop and then connect the other end into your ipod. This will then start charging for you.
Jul 08, 2011 | Computers & Internet
I have just bought a new mac laptop - how can i transfer all of music from my ipod to the new machine wihtough loosing all my songs? Is there anything i can do? Thanks
You can "migrate" to your new computer and put all your itunes library onto your new mac. You'll need to authorize the computer for access to any songs you may have purchased on itunes, but if you reached the max number of computers, you'll need to deauthorize one of the older ones first... it's all doable via the menu on itunes...
Oct 14, 2009 | Apple MacBook Pro Laptop Computer with...
My ipod holds 500 songs but I only have 320 but when I import a cd an error pops up and says my ipod wll not hold the songs
When they say that an ipod can hold "500" songs the don't actually know that it can it all depends on the format of the song, the version of firmware etc. my suggestion would be take of all your songs re-format them to mp3 or to something that takes up less space and then put them all back on and there you have it... please comment and rate for any help please pm me... lol
Jun 17, 2009 | Apple iPod nano
IPod nano 4G that iTunes no likey
reformat your ipod, if you installed itunes via disc or from file, you should have the option in itunes to restore your ipod to factory settings. If you have songs on your ipod that arnt on your computer, you will need to copy them off the ipod before you restore your ipod.
To copy music off an ipod that is YOURS (in XP) go to my computer>click on your ipod> then go to tools>folder options>View TAB>and click on the option "show hidden files and folders". Then there should be a folder somwhere in your ipod (depending on what ipod you have) that says music. Copy that folder to the desktop and filter through all of the folders inside it for your music.
Mar 30, 2009 | Apple iPod nano
HOW TO START THE IPOD AFTER INSTALLING 167 SONGS INIT
Make sure you use itunes to put the songs on.
-Aaron
Aug 05, 2008 | Acer Aspire 3680 Laptop
Error codes pop up during itunes sync!
I am now having the same plroblem. Error -48 code keeps popping up
Jun 30, 2008 | Apple iPod classic MP3 Player
IPod mini battery dies when nearly fully charged, often while skipping songs.
iPod batteries are cheap on ebay...like $5...and come with installation instructions. Try installing a new battery and see what happens...?
Feb 11, 2008 | Apple iPod mini 2nd generation MP3 Player
Apple iPod classic MP3 Player Logo
103 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
