Question about Maytag MDG2300BWW Electric Dryer
Maytag performa mdg2300bww dryer squeking loudly
Dryer is making a very loud squeking noise and it is becoming more consistent. any suggestions on how this can be solved
maytag performa dryer mdl#mdg2300bww
  • 1239 Answers
SOURCE: Maytag Neptune Dryer Model # MDE3000AYW
Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
Posted on Sep 12, 2008
  • 41 Answers
SOURCE: Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Posted on Nov 18, 2008
  • 311 Answers
SOURCE: Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
  • 61 Answers
SOURCE: dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Posted on Dec 26, 2008
  • 326 Answers
SOURCE: squeaky loud noise maytag gas dryer
Maytag dryer - common noise problems: See "how to take apart" first. The most common noise maker is the fan blower, it breaks on the motor shaft and makes a loud "rumbling" noise. Other common trouble makers are the rear rollers and idler pulley, they often can make a screeching noise.
A common noise with Maytag dryers is a rumbling noise that often still rumbles for a few seconds even after the dryer shuts off. This usually a broken fan blower, the inside part of the fan blower has rounded out and the fan blower is free wheeling on the motor shaft = new fan blower time. These pliers help make the repair a little easier...Snap Ring pliers.. From Tools Accessories section... How to take the dryer apart. Part is # 303836 for the mytang models. Maytag fan blower order link
Posted on Jan 13, 2009
Dryer is making loud squeking noise. changed rollers did not fix problem
Sorry to read about your problem, I hope this helps you out.
you must have a drum bearing issue
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Loud Rubbing noise from my Maytag Performa Dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
Jul 20, 2010 | Maytag Dryers
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
Dryer noise and no motor action
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
May 03, 2010 | Maytag PYE2300AY Electric Dryer
My dryer squeeks really loudly. SOunds like
Two areas that might squeak in this dryer are the tension pulley next to the motor and the drum support rollers mounted to the interior rear.
The manual below will cover disassembly of your machine to get inside in page 5-1 and 5-2. Other areas of the manual may or may not apply to your machine. Turn off power and gas before opening dryer case. Draw a picture of the belt travel around the pulleys before removing it. Good Luck.
Service Manual
Sep 09, 2009 | Maytag MDG2300BWW Electric Dryer
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Rumbling noise
Time to call GHOST BUSTERS!
Here is a good service!
A&E Factory Service is nation wide!
They are open 7 days 24 hours to make appointments
Aug 22, 2008 | Maytag Performa PAV2200
Maytag MDG2300BWW Electric Dryer Logo
95 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
