Question about Icm 303 Heat Pump Defrost Timer
Icm 303 how do i put the icm 303 into test mode
    Guru:
  • 462 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Defrost Board, termination defrost thermostat quick check
About the only thing I can suggest you check is the initiate termination thermostat (assuming your Heat pump works with one of these). It will be identified by 2 wires going to it and it will be clamped on the line (Not brazed on or screwed on). Now there will also be a reversing valve which has 4 tubes going to it and 2 wires. and it could have high, low, pressure switches that have 2 wires. This thermostat is usually mounted 1/3 to 2/3 way down on the coil and is suppose to be mounted on the "U - Bend" of the out door coil tubing. It usually resembles a pancake and will have a wire or metal clip that holds it securely on the coil U bend. Make sure it hasn't fallen off or come loose. This can cause your heat pump to miss its required defrost.
You can try this also. Some defrost timer boards have a set of "test pins" you put them together with a screwdriver or a piece of wire for a few seconds to initiate a defrost. It defeats the time logic in the board It should go on into defrost and stay in until the coil is cleared of frost and or about 10 minutes which ever comes first. If it comes out right away it may be the termination switch I talked about above. It could also be the board. To check out the thermostat locate the 2 wires going to it from the board. pull them off the board and retry it. Sill goes right out of defrost then jumper the 2 wires together and try it again. If it still comes out this time it most likely the board. If it stays in defrost either time when removing the wires or jumping the wires its the thermostat.
If its anything else; Well Its a little complicated and unless you understand the heat pump /refrigeration cycle and the need for defrost and how the defrost is limited and initiated, well Id say yep...you need a pro.
Hope this helps you. If so please rate me as high as you can. Thank you for using fixya and good luck.
Posted on Mar 25, 2009
Fix pats immoblizer on 1998 ford mustang.car thinks it has been stolen.car will crank but no start
If infact it is a no start because of the PATS system you will need to have it towed to a ford dealer . Nothing you can do ,unless you have ford factory servicing info. an a ford IDS scan tool .Need to start by checking for DTC'S - diagnostic trouble code's .
B1600 PATS Ignition Key Transponder Signal Is Not Received - Damaged Key or Non-PATS Key ICM GO to Pinpoint Test F . B1601 PATS Received Incorrect Key-Code From Ignition Key Transponder (Unprogrammed Encoded Ignition Key) ICM GO to Pinpoint Test G . B1602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder (Partial Key Read) ICM GO to Pinpoint Test H . B1681 PATS Transceiver Signal Is Not Received (Not Connected, Damaged, or Wiring) ICM GO to Pinpoint Test I . B2139 PCM ID Does Not Match Between Instrument Cluster and PCM ICM GO to Pinpoint Test J . B2141 NVM Configuration Failure (No PCM ID Exchange Between Instrument Cluster and PCM) ICM GO to Pinpoint Test
Dec 07, 2017 | Ford Cars & Trucks
1998 blazer 4.3l crank but no spark condition
use your key fob to start it,your security is on
Apr 22, 2017 | 1998 Chevrolet Blazer
I recently replaced the coils the icm cam sensor and crank sensor and still getting a p1350 code on my 94 lesabre . how can i fix this please?.?
DTC P1350 Bypass Line Monitor
Refer to Ignition Control, Knock Sensors .
Circuit Description
The Ignition Control Module (ICM) sends signals that the PCM requires for fuel control and spark advance calculations. At the start of engine crank, the ICM controls spark advance (Bypass mode.) When the second 3X reference pulse is recognized by the PCM, the PCM applies 5 volts to the Bypass circuit, commanding the ICM to switch spark advance to PCM control (IC mode). An open in the IC circuit or a short to voltage in the Bypass circuit at startup will cause the PCM to monitor IC pulses during crank, when the ICM should be grounding the IC circuit. This condition will set DTC P1350. The engine may be started but will run on Bypass mode timing.
Conditions for Setting the DTC
The PCM monitors IC pulses during crank while Bypass mode spark advance is commanded
Action Taken When the DTC Sets
The PCM will illuminate the malfunction indicator lamp (MIL) during the second consecutive trip in which the diagnostic test has been run and failed.
The PCM will store conditions which were present when the DTC set as Freeze Frame and Failure Records data.
Conditions for Clearing the MIL/DTC
The PCM will turn OFF the MIL during the third consecutive trip in which the diagnostic has been run and passed.
The History DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
The DTC can be cleared by using the scan tool.
Diagnostic Aids
Check for the following conditions:
Poor connection at the PCM. Inspect harness connectors for backed out terminals, improper mating, broken locks, improperly formed or damaged terminals, and poor terminal to wire connection.
Damaged harness. Inspect the wiring harness for damage. If the harness appears to be OK, disconnect the ICM, turn the ignition ON and observe a digital multimeter connected between the IC circuit and B+ while moving connectors and wiring harnesses related to the ICM. A change in voltage will indicate the location of the malfunction.
Reviewing the Fail Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
Test Description
Number(s) below refer to the step number(s) on the Diagnostic Table.
This vehicle is equipped with a PCM which utilizes an Electrically Erasable Programmable Read Only Memory (EEPROM). When the PCM is being replaced, the new PCM must be programmed.
Oct 14, 2016 | Cars & Trucks
My 91 accord has been giving me grief 4 months. Sure would appreciate any help - TX GREASEMONKEY, u have been on the mark b4, want to take a shot... Its my only transportation and has been down 4 a month....
When you say you have fuel, do you have normal fuel pressure at the injectors ? Because Honda cars are known for faulty fuel pump relays.
The relay stops powering the pump when it gets hot but will start back up when the relay cools off.
Jul 25, 2014 | Cars & Trucks
89 K1500 ICM
That info is on the internet & may be on You Tube Video as well
Just have to Google the question
I have seen it on the net
Also -- Scanner Danner on You Tube teaches a college class
on testing the ICM
Jun 10, 2014 | Cars & Trucks
94 camaro wont start...no firefrom the coil has new icm , coil , fuel pump
Check the icm plug with a led testlight for pulse while the engine is cranking. Test the wire connector with the small wires going into the coil for pulse.The v8 has a opti-spark distributor behind the waterpump that is prone to failure. It has the pickup inside it that tells the icm when to spark. If no pulse at icm distributor is bad. If pulse at icm but not at coil, icm or wiring between icm and coil is bad.The coil also needs pos.+ power on 1 terminal to operate. Be SURE to check the security light on the dash. If VATS [vehicle anti theft system] fails its usually within the 2 wires going from the key chip in the ignition tumbler to the body control module. Mine were purple and tan.Trying to start it with the wrong key can put it in lockout mode also. There are bypass modules available online for vats problems or you can even install a resistor in the wire to bypass the keychip part and the door alarms still work.
Mar 27, 2014 | 1994 Chevrolet Camaro
My ICM went out, I put another 4 on it all failed after only mins. or secs. I just put a new ICM and 3 new coil packs on it. Reconnected the negative battery cable. It started right up sounded great I...
Isn't this the wire that provides power TO the ICM not from it? if so trace that wire back and see where it does.. look for a short or open.
May 05, 2011 | 1995 Buick Regal
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
Emergency heat comes on with air conditioning
your problem is in the low voltage control circuit. disconnect the wire at the furnace that operates the emergency heat. Then see if its in the thermostat or the wiring or the board in the furnace
Aug 12, 2009 | Icm 303 Heat Pump Defrost Timer
Icm 303 Heat Pump Defrost Timer Logo
341 people viewed this question
Top Icm Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Icm Hardware and Accessory Expert? Answer questions, earn points and help others
