Question about HP Pavilion dv9720us Notebook
My laptop hp dv9720us ,......... i need to reconnect the screen .......how do i open it ?
  • Anonymous Dec 17, 2008
    give lan driver of Hp Pavilion dv9720us Notebook pc please
  • Curtis Richner May 11, 2010
    How do you know the screen has become disconnected?
    Have you tried an external monitor?
Only displays when powered up with screen at 30 degrees
Are you saying the backlighting isn't working? Or is it the on/off switch the controls the backlighting when the lid is closed or opened? Maybe tis will help: http://www.youtube.com/watch?v=2Yi6GNFcP3w Has it been dropped, jarred, bumped? Fell over? There is a ribbon cable in the rear of the monitor that can be loose.
Jan 12, 2013 | HP Pavilion dv9720us Notebook
Hard disk
flip over laptop; you\'ll see a cover with 2 screws; remove cover; you\'ll see caddy(had pull strap on it) theres your HD
Dec 21, 2012 | HP Pavilion DV9720US Notebook
I have a HP Pavilion dv9720us notebook running Vista. Since I performed a system recovery it will no longer acknowledge the CD/DVD drive. I have tried several times to redo the system recovery but still...
Try following this, XP, Vista, and Windows 7 seem to run into this problem.
It will remove the high and low filters, forceing the machine to regenrate and it somehow finds the drive again.
http://support.microsoft.com/kb/929461
Feb 15, 2010 | HP Pavilion dv9720us Notebook
The screen is scrambled at times. It seemed like
it's probably not the LCD, it is most likely the ribbon cable... it could be repaired or if not, replaced...
Nov 08, 2009 | HP Pavilion dv9720us Notebook
Sound card
I was unable to locate appropriate drivers for either of the sound systems on that model from the HP website, but you should be able to get them through the Windows Update site. Just make sure you choose the Custom button (Express only looks for critical updates) and check the drivers section to see what is available for you. I know for sure the RealTek drivers are there and I would assume that the Conexant drivers are as well, so you should be covered no matter which specific hardware configuration you have.
Mar 27, 2009 | HP Pavilion dv9720us Notebook
Sound
Sounds to me like you are missing the drivers for the soundcard...the drivers are basiclly the software thatallows your computer to communicate with the hardware (in this case the soundcard).
What you can do is download the drivers and install them , which should get you your sound back!
You can download them here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-45570-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=3224049
Oct 02, 2008 | HP Pavilion dv9720us Notebook
HP Pavillion dv9720us Notebook PC will not come on
i got mine fixed at r-tech for 160 dollars, they fixed my motherboard (818) 347-1100
Jun 25, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9720us Notebook Logo
111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
