Question about Averatec SL3150H-01 Notebook
Can't reformat hard drive
Hi, My Averatec 3150H-01 recently shutdown for no reason when trying to configure Microsoft Office. I am unable to boot up the computer. WHen I try to format the hard drive, using the recovery media, the computer will ask if I want to send some type of ghost output file to an a: drive (which doesn't exist). I have found no way around this problem so far. I gather that the computer is trying to backup some of it's files, but because it wants to do so to the a: drive, It can't, and so I get an error, and cannot use the recovery media. What should I do? Thanks in advance.. shawn
  • Shawn smith Feb 17, 2007
    smiths27 here again... I tried the above solution to no avail. Even with the first boot device in BIOS set to CDROM. I'm wondering if you could give me more help?
    It may help if I give more detail:
    The problem occures when the Symatec screen comes up. A window opens up with the question "Output A:\Ghosterr.txt" with a yes or no choice. If I choose "yes," the computer isn't able to find the drive. If Ichoose "no," It says "invalid destination drive." then the program aborts and I get an "Error 0004: recovery failure" message. This happens no matter what I do.
    I'm not concerned with saving what's on my hard drive, I just want to use my computer again. I suspect that I may have to replace the hard drive....
    Any help with this would be most appreciated,
    Thanks again,
    Shawn
    President:
  • 2,961 Answers
When the pc is booting press F8 to get into safe mode. When the menu loads up highlight last known good configuration and select. hopefully the reboot will bring you into windows. If no luck and if you have a recovery cd you will need to enter the bios F2 or Del on boot up and in advanced cmos settings change the first boot device to CDRom. Insert your disc and re boot and press any key to boot from cd when prompted. When given the option to press 'R' for repair or Enter to install, press 'R' as this willinstall windows without you losing all your documents and setings. Hopefully you won't need to do that as the first part of solution should sort it.
Posted on Feb 16, 2007
  • andrew pester
    andrew pester Feb 19, 2007
    The 'Ghost' refers to a complete duplication of your drive, normally kept on a seperate partition on your hardrive.
    Do you have a Windows installation disc with the system?
Laptop shutdown while reformatting and now unable to bootup
If it shutdown while reformatting the hard drive, restart from a installer CD/DVD and reformat the hard drive before installing the operating system.
Apr 23, 2014 | Computers & Internet
Where can I buy a hard drive for my Averatec 3150H laptop?
most "mom and pop" computer stores will carry that ide hard drive. Its a 2.5 inch drive
Sep 14, 2012 | Averatec 3150H Notebook
Boot failure
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 08, 2012 | Averatec 3150H Notebook
I WOULD LIKE TO RESTORE MY ALL-IN-ONE TO ITS ORIGINAL FACTORY STATE BUT DONT KNOW HOW
if you have CD Recovery with you, just insert the CD restart it, make sure you have set the boot order on cd/dvd drive, and follow the instruction. If you don't have, downloas from this link:
http://www.user-guides.co.uk/cddownload/Averatec/Averatec3150/Averatec-3150-XP-Driver-CD-Recovery-Restore-Disk-116374.html
Apr 09, 2010 | Averatec 3150H Notebook
So today i desided to restore my Averatec 3150H
You can get Bart PE at www.tucows.com online and look it up it will allow you to start-you have no choice. You can start up windows to look at the drive, this is assuming you have Xp or XP professional. It will allow you to reformat the drive, do not format the partition that has the drivers in it unless you have to bart pe also has a disk repair on it to allow you to fix some of the most common problems on windowsxp. If you need averatec's web site for support let me know and I can give you their 800 number so you can call them, there computers are junk I owned one had to replace three mother boards in one year.
Nov 29, 2009 | Averatec 3150H Notebook
At boot up, my Averatec 3150HS displays the error message "north bridge fan error, press F2 to continue" I can't find the fan.
Hello there:
boot into bios and look at the advanced section and see if the bridge fan is located there and if it is just enable it than press the f 10 key to save and than reboot the system
Aug 15, 2009 | Averatec 3150H Notebook
Does the hard drive interchange with other Averatecs?
Swapping hard drives only works if the hard drive is swapped into an identical computer with the same device configurations, CPU and RAM etc.
The best way to copy or recover data from a working hard drive is to insert the hard drive into an USB hard drive adapter and plug it into a working computer's USB port. You should see this drive as an external hard drive and you can then copy or backup the data onto the computers hard drive or USB memory stick etc.
May 13, 2009 | Averatec 3150H Ultra Thin Notebook PC With...
DVD/CD RW
edit the registry and delete the upper and lower filter.
In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
Right click the upper filter and delete it. Look for lower filter and delete it also. (if only one is available then its fine).
close registry editor and restart the computer.
try your dvd drive again.
***Note*** make sure to follow the instructions properly. do not delete any file, just the lower and upper filter or else system will not load to windows anymore.
Oct 07, 2008 | Averatec 3150H Notebook
Pc wont boot up after reformat.
After format your computer will not boot if don't have the Sys files on it. Try to put your hard drive back to your computer and start booting with some cd with hard drive utilities like http://www.ultimatebootcd.com/
Sep 24, 2008 | E-Machines eMachines Desktop PC
Happy New Year! How to Bypass Password
what o/s if xp home boot into safe mode
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 29, 2007 | Averatec 3150H Notebook
Averatec SL3150H-01 Notebook Logo
191 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
