Question about Frigidaire FRT15G4B Top Freezer Refrigerator
Frigidaire Model # FRT15G5AWO Top Freezer Refrigerator
Refrigerator or Freezer does not get cold. I replaced the cold control thermo couple after noticing that when the contacts were shorted everything seemed to be running. Tried to adjust the spring screw in the control itself but infortunately this just shorted the control to be always on and everything including the refrigerator ran constantly, freezing everything. The new control seemed to work at first but after the first cycle, everything stopped and did not turn on again. Could this be a defrost timer issue? If so, how can I check instead of buying more parts I don't need?
  • Peter Mora Feb 17, 2007
    The solution was a good suggestion but unfortunately when I tweeked the defrost timer nothing happened. I thought I would mention that the refrigerator is in a cold garage. Could this effect the cycle if the condenser is in a cold environment?
    Thanks for the specification, I didn't have that since I bought the unit second hand. However, eventhough it wouldn't operate proper temp, wouldn't the unit still cycle? I can still make the compressor and fans come on with shorting the contacts from the thermocouple control. Any other ideas?
Frigidaire makes a garage kit to operate refrigirators at lower temps. the kit is about 18.00 dollars, it is avaliable from electrolux,1800-599-7569
Posted on Mar 09, 2007
The food in our freezer has been icing up quickly. Then recently noticed the vegatables in the Refrigerator bins were all frozen and ruined. On inspection of the freezer, we noticed a sheet of ice running...
i would say that the cold coil in back of freezer is covered with ice and the problem will get worse . the defrost system need repair . ck the defrost thermo and the defrost control . . the heater is usualy ok . your unit may use what is a p c control called aditive defrost control . but most common is the defrost termo . located on the evap coil in back of freezer plate. mm hope this helps feed back pls .
Jan 20, 2011 | Refrigerators
Freezer is working but refrigerator is not cooling.
cold coil may be pluged with ice and you have a defrost problem / ck thermo terminator and heater . most common . if they are ok replace the a d c auto defrost control .. also very common ..
Aug 17, 2010 | Amana ARB8057CSL Bottom Freezer...
FRT17G4B Top Freezer Refrigerator: freezer cold refrigaerator not...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 17, 2010 | Frigidaire FRT17G4B Top Freezer...
Admrial LTF2112AR fridge not cooling
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Sep 12, 2009 | Refrigerators
Refrigerator is not getting cold enough
unplug Remove the cold control short the leads together (calling for cold continuously)plig back in... if this fixes it... replace cold control
Jun 13, 2009 | Frigidaire FRT18KG3CW Top Freezer...
Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Apr 28, 2009 | Frigidaire FRT17G4B Top Freezer...
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
Frigidaire FRT15G4B Top Freezer Refrigerator Logo
477 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
