Question about Frigidaire FAC124 wall/Window Air Conditioner
My Frigidaire AC/heater window unit problem is no heat. Fan works
I removed heater checked power on heat mode connections to heater which was around 320 ac. Seems too high. Is that the problem if not how can I check heater while off unit. thanks
  • 3 more comments
  • srcr1983 Dec 08, 2008
    I need to ask more questions for my problem. I did not recieve sufficient help for premium help tech. thanks.
    Thanks. The frigidaire model # is FAZ08HR1A. The heater has 2 swithches attached on top. The element has about 11 ohms. The 2 switches have 0 ohms. The main power is 110vac, the lines to the 2 switches has high VAC. Are those switches the thermal cut-off and the thermostatic switch you mentioned. Sorry for not furnishing model #. Thanks again.
    found connection to relay loose and black at connection. Heater works after connecting back up. thanks a lot. Good work
  • srcr1983 Dec 10, 2008
    Hello, I installed unit the heat isn't very hot. Its warm at best. What could cause heat to not be at its best? Could it be the heater itself? What can I check to diagnose? Thanks
    Thanis I'll try it.
There is probably something going on with the heating part of the unit, and so I would probably look at that part of the appliance if you know where to look. If you aren't sure where to repair it at, I would get a repairman to come and look at your air conditioner. It can be very difficult to fix an appliance such as this if you aren't sure what to look for! http://www.honestairinc.com/ac-repair-replacement
Posted on Oct 27, 2014
First of all, do you get cool air when it's switched to cool? We want to make sure that the freon in the lines is still good and that you don't have a broken line somewhere. If you don't have heat, it could be a number of things. My guess would be that you have a blown fuse, or a broken circuit along the way. I would put up a voltmeter to some of the inner parts of the board and check it that way.
http://www.virginiamechanical.com
Posted on Oct 03, 2014
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls check the continuity of the heater element itself. Additionally, almost always, heaters have a thermal cut-off in series with the supply line. This is different but in addition to the thermostatic switch that regulates the switching off temperature. Both the thermal cut-off and the thermostatic switch could also be checked with a continuity tester. Normally, both should read 0 ohms. Of course all continuity/resistance readings should be performed with the unit unplug.
The "320 ac" reading is unrealistic, perhaps you can try reading from the mains/outlet and compare.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 08, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Dec 08, 2008
    Appreciate the postback/comment. Perhaps if you could post the specific model number, then a more detailed approach could be forwarded.
    Cheers.
  • Louie  Role
    Your posted readings indicate that those components are good. Incidentally, the two switches are termed Temperature Limiter and Thermal Link. Both serve the same purpose, go off if the heater exceeds a pre-set temperature.
    On both the Temperature Limiter and Thermal Link, one of their terminals/ends goes to a relay that is activated by the controller board. If the heater is not heating up, it is either the relay is defective or the controller board is not switching the relay ON. Another possibility would be loose wires/pins on the connector(s).
    Incidentally, I understand that there is a TEST/RESET button on the plug itself. Of course it would help to double check that the breakers are good and set.
    To further assist you in the diagnosis, the wiring diagram, installation instructions and the owner's guide all may be found here. Of particular interest would be the wiring diagram which you can reference tracing the supply line.
  • Louie  Role
    Glad to be of assistance and appreciate the rating too.
  • Louie  Role
    Louie Role Dec 10, 2008
    Hi again,
    Appreciate the update.
    If you can measure 110VAC after the relay and likewise on the terminals of the heater, then yes the heater is not drawing enough current to produce sufficient heat. If on the other hand, the mains will read 100 but wold be less after the relay of on the heater's terminals, then something in between is dropping the voltage. One possibility is the internal contact pins of the relay.
Water heater blinks 7 times. I don't get any hot water. Model # is MITW4056FBN
Hope this helps..I have also attached a link that may be useful.
No Hot Water
REASON REMEDY No power Check fuses or circuit breaker, replace or reset. Check with utility if necessary Wrong wiring connections at heater terminal Correct according to manufacturer's instructions Leaks around heating elements (1) Tighten element (2) If necessary, clean and replace with new gasket Loose wiring connection Locate loose connections. Clean carefully (remove all oxidation). Reconnect properly Lightning Inspect: (1) fuse (or circuit breaker). (2) Heater elements, and (3) thermostat, replace if necessary, see "grounding instructions" below High voltage Check utility for correction Short Locate short circuit and correct Wrong piping connections Reconnect pipes to proper fittings according to manufacturer's instructions Undersize service wiring Check with utility co. or electrician Improper calibration Replace thermostat Faulty thermostat Replace Faulty thermal cutout Replace Open thermal cutout Reset Top heating element burned out Replace
http://www.bradfordwhite.com/sites/default/files/product_literature/48494-A.pdf
Jan 13, 2018 | Water Water Heaters
Installed an rth2510 and installed as labeled on old stat and sounds like my ac nut is buzzing outside, any thought?
question: do you have a multiple thermostat setup in 1 zone? If so check what settings are for your heat on each thermostat. Make sure that the heat is not set higher than the room's temperature.
check what settings are for your cooling on each thermostat. Make sure that the cooling is set accordingly.
if you have multiple thermostats setup in 1 zone. the thermostat with the lowest temperature will reign supreme. The heat setting on that thermostat will be what's causing the buzz on the heater.
optionally, hard reset your thermostat as a precaution. Here's how to do so: there are two types of thermostats i know of programmable and non-programmable.
disable auto & enable manual; however do NOT change settings or power-off t-stat. Remove battery and power down the thermostat until you see nothing on the thermostat monitor; power OFF the switch connected to your t-stat. Remove battery and reinsert inverted, if needed, press whatever button that your heart desires to make sure that nothing is absolutely drawing into that mode, button, etc; wait (5sec-1min); remove batters; wait 1min; then, reinsert batteries in its correct position; if you have a programmable thermostat; do the same with the hit 'reset filter' held down observe if the roomTemp reading has changed.
May I suggest to keep an extra thermometer around to determine if temperature reading accurately?
If reset requires a reprogramming to your t-stat, do whatever required to set your desired setting.
cheers, best of luck. i hope i've helped.
background, doing a hard reset in my opinion is similar to removing the battery from a PC motherboard.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Tankless electric water heater not heating
If you smell it - look fer it. It may be a bad connection on the AC supply line all the way back to the service panel or inside the heater connection panel. Bad connections cause high heat and discoloration of wires or connectors and a serious voltage drop to the appliance.
Jan 29, 2012 | Bosch PowerStar AE125 AE125 Whole House...
Lg rd3500 147* not working what doooooooo
Well first of all, I checked the manual, and this is not in there.
I was drying my clothes and it stopped working. The lights in the ring that choose what kind of a load you want...well the first three are blinking. The second two are not. It will not let me choose a load or drying time, and if I press start, the thing inside goes around once and then stops. I looked in the filter basket and there's nothing in there and I wiped the sheet off.
Now the lights aren't blinking and I can choose an option, but it only goes for like a minute and then stops
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. LEG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm check instead.
1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
2-Canister for the heater element.
3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
4-This is the terminals of the heater element that is inside the canister.
5-Thermal fuse that controls motor run.
6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.
please comment on these solution by saying how helpful.mean vote.
Dec 23, 2010 | Dryers
My dryer is no longer heating up and it does not time out, what parts would i need to fix the problems?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug
Whirlpool style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
After about an hour the breaker trips on a single element Rheem water heater. 2Meg ohm to ground from the element terminals: 700K between element termianals. theromstat connections to ground infinate. (can...
I would say then the heating element has a resistive short to ground. The 1.98m Ohm reading is high, but not high enough -- should be infinite. I would say replace heating element... And, when you install new one, make sure there is no water leaking thru heating element cavity and ensure area around cavity is clean & "in order".
How old is water heater?
Charlie
Sep 29, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
2005 KA blowing hot air out when set to cold
start car.turn on air conditioner high cool .raise hood look to see if the compressor clutch is engaged and running.if yes your ac air door could be stuck closed or the air door vacuum actutator not receiving vacuum.a vacuum line is broken or off. or the control switch bad.that control the AC and heater mode. if compressor clutch is not engagged.check for power at compressor clutch.if yes compressor clutch coil open. or the air conditioner refrigerant R 134 is low take car to a private garage with a good reputation. they wont be expensive as the dealership.have them hook car air conditioner to a manifold gauge set to check your refrigerant low side and high side pressure.
Jun 24, 2009 | 1999 Ford Taurus
Ruud heat pump high pressure cut off problem
That's going to be in your installer configuration. Check and make sure the G terminal has a wire connected to it at the tstat , and that connection it tight. In the configuration menu, make sure it is set for a heat pump, elected heat. It seems to me that the tstat doesn't know its connected to a heat pump. Should be able to locate aodel # for tstat on the back of it. And ask Mr. Google for a manual, if you don't have 1. Hope this helps!
Mar 18, 2017 | Heating & Cooling
Dryer turns but doesn't heat
the heater turns on when conditions are met;
1.) thermostat is allowing it to
2.) over-temperature device is allowing it to
3.) mode selector switch is allowing it to
4.) heater coil is continuous and not broken
let's focus on number 2. some dryers have a self-resetting device that "repairs" itself after temp drops to safe level. others have a fuse type device that must be replaced if over temperature occurs. First, test for AC voltage at the heater.terminals. if ac present, heater is broken or has faulty connection. If no AC, remove power from unit and test resistance across each device listed above. Ohms for each should be as close to zero as possible except for #4 which should be about 2-5 ohms.
Nov 21, 2007 | Dryers
Frigidaire FAC124 wall/Window Air Conditioner Logo
2,308 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
