Question about Canon EOS Rebel K2 35mm SLR Camera
Camera won't come on even with new batteries
Left the camera on the ON cycle and placed in draw. Came back a week later, realized the mistake and camera would not come on. Got new batteries - same problem. Camera is blank and nothing happens on the ON cycle. Help!
  • sbanning3 May 20, 2009
    I left my camera in the auto shoot mode for several hours. When I discoveredthe problem the camera would not work at all. I changed batteries - still isn't working. The film roll icon is flashing. A dayor so ago the ISO icon was flashing. Now this. ????
    Sniper:
  • 80 Answers
The DC-DC converter which distributes the internal voltages within the camera could be at fault. Check to see if any of the pins in the CF card media bay are bent over, if so, this is the cause of the power supply failure. Good Luck Joe Weibel customelectronics.org
Posted on Feb 16, 2007
Won't turn on,even with new battery. Turned on the first time,but 2 weeks later it won't,even charging battery again. Hardly had any use since new, appro 3 years old.
More likely to be a battery issue than the camera.
Do the batteries work in another device? They may have just deteriorated with age or being left uncharged.
Are you sure they are rechargeable batteries?
Try replacing them , even with cheap generic batteries if they are AA/AAA just to verify the camera works.
Double check you have them oriented correctly when putting them in.
Aug 09, 2015 | Nikon Coolpix S2500 12mp Digital Camera...
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
Apr 25, 2017 | Nikon CoolPix S4150
My samsung pl120 won't turn on
You need to get fresh batteries in hope it will power on.
Mar 19, 2012 | Samsung PL120 Digital Camera
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
I have a new battery.For how long should I charge it?
Overnight for the first charge, then let it run empty.
The biggest mistake most people make is to use the camera for an hour or so, and then plug it back into the charger...Batteries have a memory of sorts, and eventually this habit causes the batt to only last for an hour or 2.
Rechargeables need to be stretched out and used to their full potential, inorder to realize their full potential.
After the first full charge-full discharge cycle, let it charge for 4-8 hours (depending on the type, charger, and manufacturer's specs, of course) and then allow it to sit for a few hours after use (to cool down) before putting it on the charger.
Apr 13, 2010 | Casio Exilim EX-Z77 Digital Camera
I left the battery more than a week in my camera and now I changed new battery but still not turn on What shall I do? It was working before even I keep battery for long periods.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 11, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Low or no power even with new batteries
when you dropped it, it may have nocked something loose.
Apr 11, 2009 | Canon PowerShot A560 Digital Camera
My camera stopped working after downloading pictures
Do you think since the camera was plugged in so long that your battery may have died.
May 18, 2017 | Cameras
Camera batteries drain quickly
Open the battery door and check the contact between the camera and the batteries. Most often then not there is just a bad contact and it's ruinning your baterry life.
Make sure that the contact are well placed and that there is no rust or dirt build up around there.
Sep 23, 2007 | Olympus FE-210 Digital Camera
Kodak DX6440 won't power up using batteries
There's a chance that the drop is irrelevant to your problem. You could try using a small eraser to clean the battery contacts down in the chamber (make sure to dump out any eraser particles) and try a new CRV-3 battery, which because of it's slightly longer body produces a little more pressure on the contacts. If that doesn't work to improve things then your cam might need a repair, your call there. Good luck
May 02, 2006 | Kodak EasyShare DX6440 Digital Camera
Canon EOS Rebel K2 35mm SLR Camera Logo
75 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
