Question about Infinity BU-2 Speaker
No sound from it.
Is there a simple test to determine if it is working. I am pretty sure the connections are correct.
I guess it was working all along, but simply would not respond to the test sound from my Onyko. But when I put in a DVD it is definitely putting out sound. So I don't know why it will not respond to the test sound because all the other speakers respond to the test sound. ???
Thanks.
Posted on Dec 09, 2008
My theater doesnt give out sound will i have connected everything?
Assuming you have never had it working before, then it's likely that you have got a setting wrong.
Not knowing the make or model. What I suggest you do is do is find the speaker test settings. There should be an option to send a tone to each speaker. This will determine if you have connected the speakers right. It will tell you which speaker is being tested. If you can't hear the tone, then the speaker is not present or connected right.
Once you have done and if you still can't get sound. Try a simple stereo test source such as working CD player or tape deck. Connect to a socket and select the device function setting CD etc. Set it playing.
Do that for every device function one at a time. Follow the settings in the manual and you should get the thing to work.
Aug 16, 2016 | Audio Players & Recorders
Wiring diagram for electric pto
Hi Brian
Not sure where you would get a diagram other than the manufacturer, but.....
Surely the actuation of the PTO is done by a simple Solenoid.
Simply a coil of wire that becomes a magnet when connected to 12v & ground.
A MultiMeter or simple 12v test light would assist in determining the problem.
Good Luck
Jan 03, 2016 | Garden
I have a logic tv which is just out of guarantee. Worked perfectly. Switched it off during the weekend. When I switched it on yesterday, I have sound but no picture. Any suggestions please?
Hi CJ,
First let's make sure you simply haven't pressed the MUTE button on the TV or LogicTV set top box (if equipped - I'm unfamiliar with LogicTV but most of these problems come back to a pretty simple solution). Adjust the volume down to 1/4 level.
If that is OK, make sure that you have selected the correct audio output mode for LogicTV. Typically, a Stereo Output is offered that uses a traditional Left and Right cable and jacks. The jacks are usually Red and White and labeled L and R. Other audio options include a Coaxial or Optical output over a single audio cable. This may be call a Digital Audio or Dolby Digital output. Finally, an HDMI output may be offered that sends BOTH the video AND audio over a single cable with a wider, flat jack that looks a *little* like a USB plug.
Determine which audio type your LogicTV uses and make sure that you have directed the LogicTV to use that same connection in the setup. Next, check that the A /V input for LogicTV is ALSO using the same audio type in the TV set up. If all is set right and there is still no audio continue below.
Next, we need to determine if there is no audio on ALL input sources of the TV. Try connecting an A / V device such as a VHS, DVD, video game console to one of the other A / V inputs of the TV and select it. Start the device and once you have a picture, check for sound. if you do not have sound, there may be a problem with the TV speaker or amplifier.
If you have sound, that eliminates a problem with the TV speaker and amplifier. Remove the VHS / DVD/ Game cables from the TV input. Move the LogicTV input cables to the input jacks that were just used by the VHS / DVD / Game and see if you can hear the sound in the new input selection. If not, there may be a problem with the LogicTV set top box.
Hopefully, you've found the problem! Good luck!
Mar 03, 2014 | Televison & Video
How do I change the ink cartridge/toner in my PC-980 Canon copier?
Hey there. To change Ink Cartridges in your printer is a pretty simple process. All you have to do is simply open up the printer case and pull out the old cartridges. Then click in the new ones, and your printer should be ready to go!
Make sure to print a test page to check if everything works correctly though.
I hope I was able to assist.
Jul 28, 2011 | Office Equipment & Supplies
I just turn on my nb205 and after 1 minute or less, it turn off after a low sound, like a switch. It has not hot, it was working on battery. Now, it doesnt turn on, nor charge while pluged to electricity.
Your adapter may be bad. You'll have to test it with a multi-meter to determine if you have the correct votage coming out. There should be a label on the bottom of your notebook with the voltage rating on it. Make sure all the connections are secure on your power adapter, most adapters come in two pieces, just make sure they a snug connections.
Jan 12, 2011 | Computers & Internet
I have a aprilaire 112. How do you test the solenoid valve to determine if it working properly?
without using a meter? OK take the water line loose from the humidifier that connects to the solnoid. Turn the humidifier on or raise the humidity and water should flow. Keep in mind that if wired correctly the humidifier will only work when your furnace is running although some can be wired to bring on your furnace. You should hear or feel the click if no water comes out you may have no water flow as these valves are pretty durable and seldom fail
Dec 11, 2009 | Aprilaire 700 Humidifier
I need to change the starter on my 95 cherokee sport, what are the procedures to take it off and what tools do I need.
Pretty much a simple job...Make sure you have any security codes and radio re-set info before you begin...disconnect the battery cable from the battery (+) . unbolt starter from the engine, disconnect the wires on the starter (mark their positions if you need to). Reverse procedure to install. Of course, you have tested the system and have determined that the starter is actually bad, correct?
Oct 23, 2009 | 1995 Jeep Cherokee
No sound eonon 1012
As a simple test for the radio.. Connect both power leads, and the ground lead directly to the battery. If the radio powers up then you know there is a problem with your wiring, if the unit still does not power up, it's bad, and you are at the beginning of another rough Ebay story.
Aug 08, 2009 | Car Audio & Video
2000 Jeep Grand Cherokee remote starter keeps draining battery
A Simple Battery DRAW test w/ test light to Determine there is a Draw on Battery. With EVERYTHING OFF will determine that Something is Drawing Battery Down. Test light "Clamp on Neg" At Bat And the POKER AT CABLE, if it lights up you have a Draw
To Determine were it is, Pull Fuses out 1 by 1 Watching Light puting Fuse back in When you Pull a Fuse that turns the Test light off you found the Circuit that is Draining the Battery if it is A Circuit that Remote Starter is Connect to refer to Installer to Correct the Problem
NOTE TEST Light Connected this way and Electrical System in Tact Light WILL NOT BE LIT at ALL
Dont forget to keep doors closed during this Procedure
Jan 14, 2009 | 2000 Jeep Grand Cherokee
136 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
