Question about Lexmark Office Equipment & Supplies
Need printer drivers for Lexmark X6150 printer that is compatible with Windows Vista
  • Lexmark Master
  • 6,487 Answers
You can download the software for this printer to work with vista from this link http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Dec 06, 2008
I have a x6100 all in one printer but the drivers are not compatible for windows 7.although i download the drivers for vista it still doesn't print. thanks
Try to uninstall your printer driver. Follow steps in this article: How to Uninstall Lexmark Printers. Reboot pc when prompted. When the printer turns on, check if your Windows 7 is running on 32-bit or 64-bit System Type. Go to Start menu -> right-click on Computer -> Properties. Take note of the system type.
To download the driver, visit the Lexmark website using the links below: - Lexmark 6100 Series driver for Windows 7 32-bit - Lexmark 6100 Series driver for Windows 7 64-bit
Execute the file and follow the instructions on your computer screen.
Apr 28, 2011 | Lexmark X6150 All-In-One InkJet Printer
My impresora es modelo 4408-k02 y necesito sofware my computadora es windons 7 pero no lee la inforrmacion
Utilice el controlador de Vista en Windows 7. Antes de descargar el controlador, busque el tipo de sistema de Windows 7 (si es de 32 bits o 64 bits). En el equipo, haga clic en el menu Inicio -> PC -> Propiedades. Tome nota de el tipo de sistema. Ustedpuede descargar el controlador Lexmark X6150 de la pagina web de Lexmark utilizalos siguientes enlaces:
- Lexmark X6150 Driver para Windows Vista de 32 bits - Lexmark X6150 Driver para Vista de 64 bits
(NOTA: Esto se traduce con http://translate.google.com.)
Apr 19, 2011 | Lexmark X6150 All-In-One InkJet Printer
Where can I find drivers for windows 7? many thanks avio
The Lexmark X6150 printer is not compatible with Windows 7 OS. However, this printer will work with Windows Vista and Windows XP computer. Here's the link for the driver - http://bit.ly/d43qMR.
Aug 17, 2010 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X6150 install Windows Vista
Are you sure the printer is compatible with the computer? Most of the time you'll have a list on the side of the box your printer came in of the computers it's compatible with. Then again it could be a defect on the disk which would mean taking it back. Is the printer brand new?
May 05, 2009 | Lexmark X6150 All-In-One InkJet Printer
Have lexmark x6150,,,,,,,need driver download for vista
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
Jan 27, 2009 | Lexmark X6150 All-In-One InkJet Printer
Lexmark x6150
I had this problem also. After some research I found this was the only way to clear the cue.
Go to Control Panel > Printers > Right click on your Lexmark Printer > Select "Run as Administrator" > select "clear print cue"
It will ask you if you are sure - click yes/ok.
Your print cue will now be clear.
Trying to use task manager will not clear your print cue in the system, only the window notifying you of print cue items.
Unfortunately Vista and the Lexmark 6150 do not get along and this will probably keep happening.
Aug 07, 2008 | Lexmark X6150 All-In-One InkJet Printer
Printer not Vista compatable
Uninstall the s\w and and download the s\w from lexmark.com ....
Check if ur vista is 32 bit or 64 bit processor....(Right clikc on coputer ikon on ur desktop....go to properties..there ull find if ur vista is 32 or 64 bit processor)
choose the software accordingly
And also check if ur printer is x6170 or X6150...
NOTE: While installing....Unplug the USB cable...plug it back in whe the software prompts u to
Feb 26, 2008 | Lexmark X6100 Flatbed Scanner
Lexmark z25 drivers for windows vista
You need to go to the Lexmark support site and A) Make sure you are using the latest driver and specifically one that works with Vista and B) If none exist then your existing driver may have become corrupted...try it again (reinstall). Tango.
Jan 14, 2008 | Computers & Internet
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
