Question about Savin 9935DP Laser Printer
Savin Copirer error code sc326-00 - Savin 9935DP Laser Printer
  • Joseph Micallef May 11, 2010
    What is the model of the copier?
  • 86 Answers
SC 326: Laser synchronization detector board cannot receive the laser beam.
Replace the laser sync detector, Part No. A2935310.
Or try the following solution;
Open the front cover and remove the brown inner cover - 2 screws.
The black unit after the inner cover is the laser unit. There are 2 screws securing the laser unit - loosen them.
Tighten the right securing screw while jacking up the right side of the laser unit with a screwdriver.
Tighten the left securing screw and put the inner cover back on.
If SC 326 is still indicated after the above procedure, replace the laser sync detector or the whole laser unit.
Good luck and please rate me, thanks.
Posted on Jan 30, 2009
What is error code sc565?
If you wish to get some details; check the site linked here. Pull up older posts......
Jun 25, 2016 | Ricoh Compatible 4 Color Set Aficio MP...
I have a Savin 8035e. I had an error code SC542 and reset the copier as suggested. Worked great. Problem now - How do I fix alignment?
That error code is a dirty fuser thermistor. Clean it and go into service mode then turn off main power switch. That is all that is required. What is out of alignment?
Oct 10, 2014 | Savin Office Equipment & Supplies
Error code sc396
Drum motor bind. mechanical bind or defective motor. Hard to tell without a model #
Mar 05, 2012 | Savin Office Equipment & Supplies
My SAVIN 2575 is giving error code sc820, any idea what the problem is ?
Unfortunately, I've never seen this error, so I can't give you much help beyond what the code means and the possible solutions that the service manual provides...
Self diagnostic error: CPU - Unexpected external error or interrupt occurred.
• Controller board defective
• Software defective
The manual indicates this is a "C" type code, so this should not be displayed on the OP panel, only logged in the SC history in the machine.
Jun 23, 2011 | Savin 2575 Black and White Copier
Savin copier c2410 error code 421?
very common fault with win 7 click the above link and it will install the corrupt / missing program files
Dec 08, 2010 | Savin Office Equipment & Supplies
SC301 error code description:
Charge Corona Output Error 2
Charge Current Leak
Charge would need to change number of pieces corona wire A166 9516 (to confirm with the service repair center) Charge Corona Wire.
Hope helps (remember to rate this)
Sep 30, 2010 | Savin Office Equipment & Supplies
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
Savin 2522 sc542 error code
It's a fusing warm up error. The temperature isn't reaching the right rate within 20 seconds.
There isn't a reset procedure due to safety reasons. If you replace the thermistor, it should go away.
Mar 16, 2009 | Office Equipment & Supplies
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
525 people viewed this question
Top Savin Office Equipment & Supplies Experts
Adorjani Laszlo
George Mclaughlin
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
