Question about Compaq Presario sr1303wm Computer - AMD Sempron 3000 - 2.0 GHz - 256MB - 40GB - DVD/CDRW Combo ... (PP150AR) PC Desktop
PC turns on, but would not boot up at all
After getting several BSoD's of the BIOS, it had finally stopped functioning.
when i turn on my computer, it turns on, but the fan runs very loud and there is NO BIOS at all. normally, the CPU fan would run loud for 2 seconds, then it would quiet down when the "COMPAQ" logo appears. worst of all, my monitor would not detect the pc, but does detect my other computer. i tried resetting the BIOS by removing the battery, didn't work, nothing smells burnt neither. anyone knows what happened to my computer that it won't boot up at all and how to fix it (if possible)
this computer has been ONLY upgraded once, with 1024MB of RAM
  • crazychrist6 Dec 07, 2008
    here's the machine in action:
    Novelist:
  • 171 Answers
There's a good chance you've "bricked" the computer by damaging the bios. You don't smell burning because it never got burned - but the data on it is still corrupted.
Look for a jumper on the motherboard called "CLR_CMOS". If you find it, unplug everything, and move the jumper to cover those pins, wait 30 seconds, then put the jumper back. That is a full cmos reset and it's the only thing you can try.
If that doesn't work, u nfortunately you'll have to replace the mobo to fix it, and if you're going to do that, you might as well get a new computer
Posted on Dec 06, 2008
  • Frosty555 Dec 07, 2008
    I have a sinking feeling the motherboard is toast.
    But here's some things you can do. Try to start computer after every step, so you can isolate the problem:
    1) Remove both of those cards in the pci slots on the offchance they're causing a hardware fault.
    2) Remove your ram, doublecheck that it IS PC2700 DDR ram and NOT PC3200. Replace with a stick that is PC2700 (e.g. the old stick) if necessary. Reseat ram carefully and make sure it's fully in and clasps are closed.
    3) Firmly push the data cables into your hard drive and CDROM drive
    4) Trace the wire that goes from your RESET switch to your motherboard (it's one of those white ones). It will go to pins on the motherboard and will be labelled "RESET SW". Remove it from the motherboard. You may leave it removed the switch just won't work.
    5) unlatch your CPU, then relatch it. Do not remove the cpu or heat sink. Just unlatch and relatch.
    6) Try to find the "CLR_CMOS" or "CLR_PWD" jumper on the motherboard and ensure it is in the correct position. The jumper should not be crossing the two pins. It should be offset to the side.
    If all of that doesn't help.... the motherboard is toast. Unfortunately your computer is Socket A, which is hard to find a motherboard for, so you'll probably need to replace the whole computer.
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Acer M5641 :: System won't boot...tried to run restore CD DBAN...both programs freeze before the processes start...can't boot into any safe mode w/o it locking up...sometimes I get a black screen,...
try to reset computer first by unplugging it from the power supply for 5 minutes. Then while the unit is unplugged try to remove the CMOS battery and put it back in.. this eliminate if the BIOS is the one causes this to happen, then turn the computer on. If still the same turn computer off, then remove the video card and put it back in and try to turn computer on if it's still the same. Try to re-install OS.
Sep 10, 2010 | Acer Aspire M5641 PC Desktop
Having trouble starting up got to a blue screen that says a problem has been shut down to prevent damage to your computer and stop 0x0000007e(0xc000001d,ox80537008,oxf78a2598,ofx78a2204) what do i need to...
Confronting Blue Screen of Death popularly known as BSOD is one of the worst nightmares for any computer user. It can happen in all the Windows versions. Win 7 is no exception to it to BSOD. Luckily, there are ways to fix Win 7 Blue Screen of Death problem.
Usually with BSOD, one can not do any work on computer. Computer hangs, restarts or shut down on its own. There is always a great danger of losing unsaved work.
The situation demand urgent action on your part to continue safe and smooth computing.
I am sharing few tricks of the trade that will surely help you whenever you see tragic Blue Screen of Death in Win 7.
Aug 17, 2010 | E-Machines eMachines Desktop PC
Win 7 blue screen of death on shutdown? happens on one in five shutdowns the others take several minutes (10) to complete the process.
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 16, 2010 | Dell Computers & Internet
BLUE SCREEN
Then press any key.
Then type "y"
Jun 06, 2010 | Dell Dimension E520 PC Desktop
Blue screen Technical information stop: 3A0x00000024 280x00190203 2C0x81B599F8 2C0X0000102 2C0x00000000
Then press any key.
Then type "y"
Mar 04, 2010 | Dell Inspiron 2200 Notebook
BSoD on Toshiba Satellite P200-16B
you can look up the stop error for 0×0000007E at this site:
http://aumha.org/a/stop.htm
There are several MSDN articles for this issue
Jan 20, 2010 | Toshiba Satellite A85-S107 Notebook
BSOD when turning compuer on c0000021a
You need winxp bootable disk for format or repair your winxp.
Then boot your computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then set first boot device in bot option as your cd or dvd rom.Then save settings .
Then put your disk in rom then it boot with it.
Aug 01, 2009 | IBM ThinkPad R51 Notebook
System Lagging, BSOD, etc.
try to boot in safe mode, if the problem persists then try to boot in last good configuration(for both you have to press f 8 when the bios screen comes when pc is booting)
if all fails then reinstall you operating system will solve the problem
May 30, 2008 | Acer Aspire 5100 Notebook
Compaq Presario sr1303wm Computer - AMD Sempron 3000 - 2.0 GHz - 256MB - 40GB - DVD/CDRW Combo ... (PP150AR) PC Desktop Logo
116 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
