Question about Zanussi Washing Machines
Zanussi ZWF 1021 W The door won't release after the end of any cycle, even empty or spin. What can I do to get the clothes out?
  • Zanussi Master
  • 3,463 Answers
If the m/c has water in it, then the door lock will remain locked.
Lower the drain hose down into a bucket oe something and let the water run out, it should now spin, but keep the hose laid down.
You should then be able to open the dooor.
Check the pump filter, and that the pump is working o/k.
Please leave feed back
Posted on Dec 07, 2008
  • 135 Answers
First thing would be to check the filter at front of machine as any blockage will cause this problem.
Try this and come back for further assistance.
Hi my zanussi washing machine will only spin slowly and there is scale in the drum and on the clothes
the evacuation pump is either blocked up
or not running
i would remove the blockages
then run through an empty load cycle of 95deg white wash and some calgon tablets
Mar 09, 2015 | Zanussi Washing Machines
Why is the drum on my machine isn't moving?
check ur drum belt or the wheel pulleys and in some cases the center bearing and shaft? my suspicions lie with the pulleys fairly inexpensive and not to hard to replace
Jul 25, 2014 | Zanussi ZWF1230W Front Load Washer
Our Zanussi ZWF 1421W won`t stop properly, at the end of cycle start/pause button is flashing. I have to turn it to 0 and wait 3 mins for the door to open. My washing was quite "warm"when I took...
Could be water still left in the machine because the drain pump cannot operate efficiently so try this-
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 11, 2011 | Zanussi Washing Machines
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
I have a zanussi zw1125 washing macnine im finding it difficult to operate sometimes the clothes are not spun out and i cant get the spin to work can you give me the download instructions for this model
You can download the manual at:
http://dl.owneriq.net/2/2ff74170-aa6b-46f6-a0eb-cfe82f3eb026.pdf
I would suggest that you go straight to "Cleaning the pump" on Page 18. I would strongly suspect that this may be the cause of your problems.
The empty cycle is timed and if it can't get all the water out in time because the empty pump filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
Jul 06, 2011 | Zanussi ZWF1440 Front Load Washer
I cannot get my washer to release so i can open it up and switch clothes over.. It has finished its cycle i even made it do another cycle to try and get it to release but it wont.. any suggestions? Kat
There are many reasons why the door may be jammed shut -
1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
2. Washing machine won't empty water
3. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
4. Door interlock jammed
5. Door catch, handle, or mechanism broken
Try running Just the rinse spin cycle again,
Jul 05, 2011 | Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
250 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
