Question about Toshiba SD M1612 Internal DVD Drive
My toshiba sd m1612 doesn't play about hapf my DVD's
My toshiba sd m1612 started a few weeks ago not to play about half of my dvd's. All my dvd's are originals, bought in good stores.
When I insert any of these DVD 's the light on the front of the DVD blinks about ten times and then stops blinking and remains ON, indicating the DVD can't be read. Windows says that the DVD is either corupt or has a format not recognized by Windows.
I moved the player to another computer, went through installation, no change.
It's like the hardware of the player changed.
I tried a lens head cleaner -no change.
Thanks,
Nitzan
    Master:
  • Toshiba Master
  • 543 Answers
Nitzan,
OK... sounds like dirty Laser Optics to me...
There are CD CLEANER disks that look like a regular CD, BUT on the bottom there is a tiny (real) "brushes" that cleans the dust and dirt away from many/most CD/DVD devices!
I don't recommend that you use it too often because you do not want to SCRATCH your Laser Optics with dust or dirt... you just want to clean the laser face...
About $2.60 (free shipping) on EBAY
Here is a quote:
Description:
  • 100% brand new and high quality
  • Designed to efficiently clean the laser of your valuable VCD/DVD/Computer/ Laptop/CD-Rom/DVD-Rom
  • Improves sound quality, and optimize performance of your players
  • Perfect to keep your Disc drives clean and operating well
  • Safely clean and remove dirt and dust from your players
  • Easy to use, simply insert the provided optical Disc/CD into your player
my toshiba sd m1612 doesn't play about hapf my DVD - cd cleaner-sfxhblc40x3yl02vv3vzvmau-3-0.jpg
Posted on Nov 29, 2017
3 Suggested Answers
  • 8 Answers
SOURCE: DVD not working
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Posted on Sep 17, 2008
SOURCE: Toshiba SD C2512 reading DVD but not Cd
solution for CD-rom problem: turn CW the second little potentiometer with a tiny screwdriver, just a little and try to read a CD, if it doesnt work then try turn the potentiometer again. the same solution for DVD-rom but with the first potentiometer.
Posted on Feb 21, 2009
Erratic operation of DVD players after a few months of non-use
what you should do is to clean the OPTICAL LENS directly with a dry Q-tip , could be that it collected some dust and thats why its playing erratically, give it a try , AJ
May 29, 2009 | Toshiba SD-1800 DVD Player
My toshiba laptop satellite A215-s7422 doesn"t play anymore
Assuming you have tried various DVD's & CD's sounds like a bad CD/DVD drive. These use a lens mounted on a moveable mount to focus the laser beam and over time the mount gets worn out and the beam can no longer focus so the drive can no longer read the DVD/CD. Should hear the DVD speed up then slow down and maybe a loud vibrating noise (Lens trying to focus). Can try a laser lens cleaner - you can get them at Best Buy, but if that does not work then a new DVD drive is in order. If you can change it yourself then you might find one on ebay used for @$25 otherwise a trip to the computer repair shop.
Apr 14, 2009 | Toshiba SD C2512 (SD-C2512) Internal DVD...
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
TOSHIBA SD-1600 WILL NOT PLAY DVD+R RECORDIBLE DISC.
wer i can find the model of the toshiba dynabook video driver?
Dec 22, 2008 | Toshiba SD-1600
Toshiba sd 220e dvd player
CDR
CDRW DVD-R
DVD-RW
DVD+R
DVD+RW
DVD+R DL VCD
SVCD It plays PAL and NTSC apperently.
Here is a link to comments and more info of what this player plays-
http://www.videohelp.com/dvdplayers?DVDname=sd+220e&Submit=Search&Search=Search&dvdportable=&dvdchanger=&dvdtv=&chipset=&orderby=Name&hits=50
Hope this helps.
Aug 15, 2008 | Toshiba SD-220E DVD Player
Not playing DVD's
have you asked for profesinl help or take it apart to fix the problem
Dec 18, 2007 | Toshiba SD-P1400 Portable DVD Player
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
DVD stuck
Replace the drivebay of the Bose AV3-2-1 If the drive sticks, or does not open, or If you receive an error of NO DISK, or any indicator that the disk is not properly recognized clean the lens and if still doesn?t work then the DVD drive is bad. You can actually use one for a desktop PC with a few part swappings. Check that the drive is a Toshiba SD-M1612 it is printed at the bottom of the drive bay. To use this SD-M1612 as a replacement you will simply have to swap three external parts. Remove the 3 parts from the bad Bose drive bay: Remove the 4 bottom bolts, lift cover, if the DVD bay door is locked then insert a paperclip into small hole in the front. Slide DVD tray out and remove the PC style DVD ROM tray facing. 2 clips hold it on pry them out and slide the facing up and off. Now remove the face of the drive bay. It has several clips. Save these three components (top cover, face, and tray facing) to add to the new Toshiba SD-M1612 DVD bay. Remove the old and installation is the reversed procedure above. also remove the small clear LED bezel from the new drive before adding the face. It works fantastic.
Mar 26, 2007 | Bose 3·2·1 II System
Toshiba SD M1612 Internal DVD Drive Logo
104 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
