Question about Hotpoint TDC32 Electric Dryer
Cutting out after a few minutes
My condenser drier cuts out after a few minutes, after a while it wil start again but runs for less time. I have cleaned out all lint etc. from the system and replaced thermo cut outs but is exactly the same.Any suggestions. Machine is actualy a TDC30
  • 247 Answers
Is the water supply (for supplying cooling water to the condenser) switched on? If not, there's no real mechanism for removing heat from the machine, and it might reasonably be expected to shut itself down. Once you've got water going to the inlet hose, you might check that the solenoid valve which shuts the water off when the machine is turned off hasn't failed, and that the jet through which the water squirts into the condenser (if that's separate in this model) isn't blocked. A.
Posted on Feb 16, 2007
Diesel engine runs then stops then runs stops every few minutes
Mate I use to drive a freightliner and it cut out on me one day, I eventually got it started but cut out again after about 5 minutes, I rang a mechanic to come out and he found a heat sensor wire came off the radiator and that caused the motor to cut out... Hope I haven't wasted your time.......
Mar 09, 2016 | 2007 Chrysler Grand Voyager
Kenmore king size capacity 90 series
could be thermal overload in motor its a motor protector in the motor when the motor gets hot it cuts power to the motor when motor cools it closes and resets age of drier counts some times you can take drier apart and blow dust out of motor and will fix now if the door is not closing tight vibration can cause door switch to break contact that will do it too most of time motor or relay must be replaced
Jan 06, 2008 | Kenmore 63942 Dryer
Weller Pyropen WPA2 extinguishes itself after a few minutes.
Gas (condensation really) may be freezing and constricting flow. Try warming the tip a bit with a hair dryer see if it goes longer.
Jan 11, 2014 | Weller WPA2 Pyropen Professional Self...
When driving suddenly the engine cuts out.
I heave the same problem on my Corsa B 1.0 2000, engine cuts out, and whe it happens, I hear one of the relay under the right side of the dash buzzing. After a couple of minutes, starts like nothing happend.
So far I manage to find that the speed sensor is faulty, when I tap him the car stops. I order a brand new one, but I'm not sure that was the issue.
I order also a Opel Tech2 tester from ebay and it has to arrive next week, then I can see the error code.
Jul 13, 2012 | Opel Cars & Trucks
Engine acts like it is out of gas keeps stalling i can turn it off for a few minutes will run for a mile or two then does it again
Vent valve has failed closed or cannister is clogged up. Have the evap system checked from the tank to the charcoal canister. If you need to drive to a mechanic, try driving with the gas cap loose.
Dec 16, 2017 | Hyundai Motor 1999 Elantra
The engine cut out then right away was running again then 20-30 seconds later completly cut out again. After a few minutes it started again and ran for another two days. Then it cut out again, ran for...
- When was the last time this car had a tune-up? Could be as simple as that. New spark plugs/rotor/distributor cap/condenser might do the trick.
Other causes could be:
- bad fuel pump relay (definitely first on the list of things to check, and cheapest to fix)
- clogged/old fuel filter
- bad fuel pump
Mar 01, 2011 | 1991 Honda Civic
Unit stops rinning after 15 minutes ande a sign appears in the window saying c6. turn off unit at main switch and wait for 15 minutes and unit starts adain for a further 10 to 15 minutes and cuts off...
Compressor run current high. Check condenser coil dust blocked. Clean it. Check fan motor- if less rpm, replace capacitor.
Best solution:Do water Service and then check. If still amps gradually increase, replace capacitor.
Thanks and hope helpful.
Jan 28, 2011 | LG Heating & Cooling
Motor starts and runs for less than a minute then cuts off and WILL NOT CRANK OVER again for 15 to 20 minutes. then it cranks over, starts, runs less than a minute and cuts off again. it has been fine...
It sound more like a plugged catalytic converter. When you start the engine the pressure starts to build until the engine sufficates then after you let it set the pressure bleeds off and lets the engine restart.
Jun 23, 2010 | 1989 Chevrolet Suburban
I have a dodge truck and the ac works good and
ac pressures are ok, is the return pipe as drier sweating?, if not recharge system, if so you have a problem your fin sensor not reading evap temp, scan tool would be nice to monitor temp, but easy to get at , behind glove box, held in by a rubber gromet, also jump cycling switch on drier to see if it runs longer then 5 mins,possible charge again. GOOD LUCK RDJRP
Jul 10, 2009 | 1999 Dodge Ram
Hotpoint TDC32 Electric Dryer Logo
352 people viewed this question
Top Hotpoint Dryers Experts
jimorris77
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
