Question about Kenmore Oasis HE 27082 Top Load Washer
I have a a kenmore oasis ld error cod - Kenmore Oasis HE 27082 Top Load Washer
  • EEAGLE5 Dec 07, 2008
    i have F1 CODE
  • breezy2 Dec 12, 2008
    is this the computer or is it just a bad washer?
  • 412 Answers
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Hope this helps.....
Posted on Mar 20, 2009
Had the same issue.
On start; Drain pump could be heard running. If it did work; towards the end of the cycle LD “long drain” would display with a beep. Sometimes, it would reset by leaving unplugged for >30mins (recommended to clear keep alive memory). Other times it took all night to reset {random resets explain why it works then doesn’t} which lead me to the idea of re-calibrating the pressure transducer.
TO PREVENT IT AGAIN,
The tub, drain pump, and pressure measurement cavity was VERY dirty; I now see the Manual says to run a Bleach Clean Cycle which I do believe will keep this from happening again
TO FIX IT, I did 2 things:
(1) cleaned the basket “big stainless clothes holder” by removing it from the drum
(2) re-calibrated the Water Level and Pressure Transducer; Test #6 page 12 of Tech Sheet
Checks:
  1. Verified pump was in spec. NOTE: out of spec is tens of ohms to infinity. E.g. if yours measures 14.5 ohms or 15 it is fine. This pump is nothing more than a giant fish tank motor i.e., not much to go bad.
  2. Verified the tank is indeed draining
  3. Removed the pump to make sure it was clear of objects and debris
  4. Ran Auto Diagnostics Tech Sheet page 2; it would not pass C7 to C8
  5. Ran Console Diagnostics to verify User Interface Board
Note:
(a) washer had no other stored codes; it only had the intermittent F32 which is LD “long drain” As said, this one has no F1 or F51 codes which indicate a main controller failure and RPS failure.
Tools
Two flat putty knives
7/16 socket
Multimeter capable of 0-20ohms
Know How
(1) Need to know how to lift the main washer cabinet cover from the base. If you look in the seam along the front of the washer where the top meets the front, there are a couple of release tabs located about 2 inches in from each side. The top is hinged in the rear.
(2) Remove the Tub Ring by releasing the tabs with a small pick
(3) Remove the Impellor Cap by gently prying with fingers. The Drum is held in with the 7/16 bolt viewed under this cap.
(4) Need to know how to read and run Diagnostics.
Posted on Jan 04, 2009
  • 91 Answers
Ld error code is long drain some thimg clogged up pump ,, first check drain hose could be too far down and siphoning,, if not repl/ or cleaned out pump.....
4 Suggested Answers
  • 135 Answers
SOURCE: ld error code on kenmore oasis
ld stands for long drain. If you can remove the bottom panel you will see the pump in the middle front which has a clean out you can unscrew. There is usually obstructions in the clean out such as a sock causing the long drain. When u remove the clean out cover alot of water will come out so a wet vac comes in handy.
Posted on Apr 15, 2008
richardsimpl
  • 230 Answers
SOURCE: kenmore oasis code ld can you help
HI There
I want to say is Merry X-Mas and a Happy New Year. I have found what you need and hope this get's you in the right direction. Let me know how it went.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best Regards Richard
Posted on Dec 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis HE top loader has LD error code
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 17, 2010
Kenmore Elite Oasis Washer Error Code Ld
LD probably means the LID SWITCH has failed
Aug 10, 2016 | Kenmore Washing Machines
Kenmore elite oasis top load error code Ld
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis is beeping with an error code of Ld
LD code is long drain,one of two things the drain pump is frozen and need to be replaced or there is somthing in the pump.Pull the washer away from the wall a bit and get a bunch of towels.Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
Apr 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Ld error
Ld - Long drain - Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
Good Luck!!
Thanks
Jun 23, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
LD error on Kenmore Oasis HE 27082
I had the same problem with F1 and F68. I just bought a $345 new computer for my washer. These machines are defective. Mine was purchased in Nov. of 2006 but not even out of the box until Jan. 2007!!!
Ld error code on kenmore oasis
Apr 15, 2008 | Kenmore Oasis 27042 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
666 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
