Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refrigerator or freezer will not get cold
My freezer thawed out and no more ice is being made with my
ice maker. The motor is running but refrig is not getting cold.
I hope you have a solution.
Thanks
bellstar2.
  • bellstar2 Dec 06, 2008
    Thanks dej411 that`s probably what the problem is needs more
    freon.
  • 88 Answers
It sounds like maybe a freon problem,you might want to have a qualified technician check it out or get another opinion.
Posted on Dec 06, 2008
  • darrin johnson Dec 07, 2008
    thats okay,i knew a couple of people that had that problem and that was what it was.
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
I have a GE refrigerator model # GSH25KGMB WW. It is a side by side with an ice maker and water dispenser. We have had it for about 9 years now. The ice maker hasn't been working right for about 6 or 7...
you could have several problems.
Since you mentioned your ice maker not working right - first check to see if your ice maker is hot (be carefull it can burn you if it is hot) - it is possible for an ice maker to hang in the heat cycle of the cycle producing excessive heat in the freezer. If this is the case unplug the ice maker and/ or just replace it.
The refrigerator gets it cold from the freezer so if the freezer is not working right, you'll soon notice it in the refrigerator side.
You can also check to make sure the evaporator fan motor is running(in the freezer) and the condenser motor(at the compressor) as well.
Also check the back panel of the freezer for excessive frost build up.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I HAVE ICE BUILD UP IN THE BOTTOM OF BOTH THE FREEZER AND REFRIG. I HAVE THAWED IT OUT SEVERAL TIMES AND HAVE DISCONNECTED THE ICE MAKER AND STILL HAVE THE PROBLEM.
check the drain hole in the back it may clogged or blocked with ice make sure to clear it out to allow the water to drain into the drain pan.
Jun 10, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The refrigerator side is not very cold (mid 40's-50) but the freezer is fine. Not much cold air entering through vent in the upper left side of the fridge.
check the fan and the damper behind that vent if iced up thaw out damper --if fan blocked or iced up clear if fan not running test fan repair or replace if not running -refrig side is cooled by air from freezer side
May 31, 2010 | Kenmore 57029 Side by Side Refrigerator
The freezer is cold but the refrigerator section is not getting cold...it is not warm but not cold according to the dial settings
check the operation of the damper door between the freezer/refrigerator section which lets cold from freezer into refrige compartment for ice build-up which will cause damper door to not open fully and cool the refrige compartment,if this is the problem,unplug the door ans remove and let thaw then replace and try it then
Jan 09, 2010 | Kenmore 64802 Top Freezer Refrigerator
GE refrig Model # GSS25WGMD WW freezer is cool, compressor is running, but food is thawing out, ice has melted...not sure if I left door open ovenight, should I call repair..show long does it take to...
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Jun 25, 2009 | GE Refrigerators
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
62 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
