I have a Gateway laptop computer with XP. It originally had 512mbs of memory. I bought 2gigs of memory and installed it. It worked lightening-fast for about one day. Here is what happened: My wife closed up her Dell laptop and then sit the Gateway on top of the Dell to do some work. After about 30 minutes of using the Gateway, it blacked out. No power or anything. I took the new memory out and reinstalled the old memory; still nothing. What should I do?
  • chadwickives Dec 07, 2008
    TechJuIi,
    Thanks for the reply.
    I was grounded when I changed the RAM.
    My model is: Gateway MX6439 Notebook
    I did reference the RAM and learned that the system could handle up to 2Gigs.
    However, would too much memory damage the system?
    Novelist:
  • 157 Answers
I was initially confused about the addition of the Dell laptop in the plot before realizing what you are saying:
I think its your RAM. Did you ground yourself while removing or replacing the ram to prevent static shock from damaging the device or memory sticks?
If not, try getting another 512 stick (pretty cheap) from best buy for your gateway and testing it out. Save the receipt.
Also, post the model of your gateway laptop as some computers can not handle large amounts of ram. Most will only allow up to 2x the original amount.
Posted on Dec 06, 2008
Packard bell easynote M5284 - black screen after installing new RAM
Sounds like the memory is incompatible with the laptop. Remove the memory and install orginal memory and boot again to see if every works correctly.. If so then either a memory module is bad or motherboard wont support the new memory (size or type)
Mar 14, 2013 | Packard Bell EASYNOTE M5284 COMPATIBLE...
I upgraded my GATEWAY MX6959 LAPTOP memory from 1gb to 2gb speed 667mhz and 6400 i researched and it said it would work, i had windows 7 ult installed after memory upgrade it wont boot up and ask to
Have you ever booted in win7? It may be a win 7 issue not a memory issue. Does it boot with the 2 512 MBs of memory. unplug, remove battery, install the 512 MBs memory, reboot.
Dec 17, 2012 | Gateway mx6959 core 2 duo 1.66ghz 1gb...
Xp installation problem
Goto bios - disable sata operations and select hard drive type as normal, disable ahci, disable acpi
May 29, 2010 | Gateway T-6330U Notebook
the system doesn't accepts the lower version of windows if you are having the latest version than xp. for thi you must format the two OS softwares and first install lower version i.e., xp and then by dual booting you can also install vista or windows 7. then you can use both versions..
Problem loading OS on Gateway MT6451, Main File Error
This looks like a corrupted file in the boot section or a virus attack. the only solution is to reinstall the OS. there is no hardware error, if you had any hardware error the display will not be working fine. reinstall the Windows OS.
Please encourage us if this tip was helpful to you.
Apr 02, 2010 | Gateway MT6451 Notebook
Gateway M465-e laptop won't detect hard drive for XP install
The Gateway M465-e is only compatible the SATA hard disk drives. If the drive you are using is not a SATA drive, then it will not be able to work with your hard drive.
Dec 18, 2009 | Gateway Computers & Internet
I installed a 1g memory card in my gateway mx7118 and when I turn my computer back on I get a message to Press F11 to start system recovery 2, but nothing happens when I do that. If I remove the new card...
there might be any problem in tat card...or u have not fixed it correctly......check it properly for silly mistakes............or change ur memory card
Oct 31, 2009 | Gateway MX7118 Notebook
WinXP Pro - can't install from my original CD
Can you read the CDs in the windows? If not, the CD drive was dead.
Nov 16, 2008 | Gateway MX6920 Notebook
Memory Installation Problem
if you're using windows vista, you need to upgrade to service pack 1 to make the RAM work on your computer. before installing the RAM on your computer, be sure that you already didi power reset. turn off the computer. unplug the ac adapter and remove the battery pack. press and hold the power button for 10 secs. reseat the RAM in the computer. put in all power sources back to the computer.
i hope this info helps.
Sep 11, 2008 | Toshiba Satellite A55-S106 Notebook
Memory Problems for a Gateway Mx3215 Laptop
There are two different memory modules for that series.You can determine which you need by the chipset for you machine.If you have a Via VN800 Chipset You need the 1024MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v. If you have the NVIDIA nForce 410 Chipset The you need the 1024MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v Hope this clears up your problem
Sep 29, 2007 | Gateway MX3215 Notebook
Computers & Internet Logo
David Payne
David Payne
