Question about Sewing Machines
Singer 20u professional
Why does my sewing machine keep coming unthreaded?
SOURCE: need manual for Singer sewing machine model#100, about 12 years old
I have a manual for this machine..is there something specific you needed to know from the manual?
Posted on Mar 27, 2008
SOURCE: How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Posted on Sep 17, 2008
  • 323 Answers
SOURCE: how do I thread a singer / 20u professional?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way. This is an Industrial machine and the needles do not have flat sides. The long groove goes to the front of this machine and it threads front to back.
Sewman7
Posted on Dec 05, 2008
  • 43 Answers
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
Posted on May 06, 2009
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Posted on May 07, 2010
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
Is there a Walking Foot for the Singer 20U43?
This is what shows on eBay for Singer 20U foot.
http://www.ebay.com/sch/i.html?_from=R40'R40&_sacat=0&_nkw=Singer+20U+foot&_sop=15
I don't find these for 20U43 so one size MAY fit all.
Feb 05, 2015 | Singer Sewing Machines
My needle keeps coming unthreaded when sewing
normally when you use longer thread tails of 4 to 6 inches and move
the thread tails behind the needle before starting to sew.
Mar 07, 2013 | Singer 7436 - INGENUITY
Need owners manual for singer sewing machine 20-13
User Manual: http://www.parts.singerco.com/IPinstManuals/20U.pdf
Parts list: http://www.parts.singerco.com/IPpartCharts/20U11_13.pdf
Service Manual: http://parts.singerco.com/IPsvcManuals/20U.pdf
You are probably out of time. But check to make sure you have the right needle and it's fully inserted first.
Good luck
Nov 03, 2012 | Singer Sewing Machines
Hi, i bought a used singer 20u sewing machine, but i couldnt use it because the bobbin case does not lock into the hook, and the bobbin is not very stay firm on the case, the thread is hard to pull once I...
since the machine is used, I suggest having the machine serviced
they can check to see why the bobbin case doesn't lock into the hook, the bobbin case may have to be replaced or it could be the hook needs to be replaced, the sewing machine shop will be able to tell you for sure.
May 29, 2012 | Singer 20u Sewing Machine
I have a singer 20u, the bobbin always drops when i put it in , i cant sew at all.please let me know how to fix it.
it's very possible that there is something wrong with the bobbin case or the hook & hook race, only a sewing machine shop can tell you for sure what wrong with the machine
Free user manual
parts.singer.com Go to this address & it will help u. I have a singer 20u professional & I found an online manual there.
Dec 04, 2008 | Sewing Machines
Sewing machine either breaks thread or comes unthreaded every time i try to sew.
Your threading is not right, totally remove your thread and rethread according to the manual directions and dvd. If, you still have problems call Singer at 1-800-4singer
Sep 29, 2008 | Singer 3116 Simple
Sewing Machines Logo
266 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
