Question about Panasonic Home Theater System System
SC-pt750 - screen says CT-Mode wont change
The display says CT-mode. can turn it on and off. And if there is a DVD in there is plays. But cant use the remote to control anything... What does CT-MODE on the display mean?
  • Anonymous Jan 30, 2009
    same problem - anyone know why this happens so i can avoid it in future? i just hooked up a new dvr cable box - maybe a power issue?
  • 9 Answers
Try cold start.
Power off main set manually by press power button on main set.
Unplug power cord from main set.
Wait for about 5 sec.
[Without plug in power cord] Press and hold "Power" button without release it.
Plug in power cord (must have power) to main set by using another hand [while another hand still press on main set power button]
Keep holding until u see ------ on main set FL display.
Then release you hand which just now pressed on main set.
Power on main set again by manual press power button on main set.
Result should be OK (unlocked)
Posted on Jan 06, 2009
This just happened to me - the problem was a dvd slipped out of place in the turntable. I removed the top cover (4 screws on sides, 3 in the back), removed the disc and replaced the cover. Everything worked normally afterward.
Posted on Nov 09, 2012
Panasonic DMR-EZ28 has RC2 display /l cant see an enter button to try pressing 1 then enter
the unit has been changed to remote control 2 mode. Look in the owner's manual and change the remote to mode 2 and you should be fine.
Feb 20, 2015 | Panasonic Televison & Video
Ct-90303 remote codes
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Apr 06, 2012 | Toshiba CT-90303 Remote Control
I have a toshiba ct 90159 - I need the code for a coby dvr model dvd 627
u should be able to
turn the dvr on
press and hold the setup until the light stays on (remote)
hit the dvr botton on the remote the light should blind once
hold the remote towards the dvr keep hitting the on and off button on the remote until the dvr turns off can take up to 300 times once the dvr turns off press the select button and that should fixya up
Mar 31, 2012 | Toshiba CT-90159 Remote Control
Says ct mode on my cinema sc-pt750 and i cannot lower or increase volume
I am assuming you have got a panasonic DVD Home Theater Sound system.
Please confirm whether the display shows CD MODE or CT MODE. I am not sure if there is anything like CT mode.
It is possible the CD Mode button on the remote unit has been pressed. In this case press the CANCEL button or the CD Mode button and see if the system is operating otherwise.
In case you do not have the manual see this site.
If this helps then please accept the solution otherwise post a comment with some more information on what are you actually doing with the system when the problem occurs.
Sep 05, 2011 | Panasonic Home Theater System System
Programing my toshiba ct-90157 remote to a sanyo dvd player
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 11, 2009 | Toshiba CT-90157 Remote Control
I had the same problem, and the solution above/below that says to use code 018 worked for me. Yeah!!!
Sep 01, 2008 | Kenwood RC-R0720 Remote Control
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Parental Lock Feature
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Feb 21, 2008 | Audio Players & Recorders
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
Panasonic Home Theater System System Logo
1,102 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
