Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Took apart poulan wildthing blower because it would'nt start. googled the problem and found out the head bolts might be loose and they were,put antiseize on them and tightened them back up problem is when i went to put it back together a piece fell out , it's about an inch and a quarter long by a half an inch wide with a round tube on one end and a flat piece on the other end?
  • Jim Giesen May 11, 2010
    have you fixed it
2 Suggested Answers
SOURCE: gap setting poulan wildthing blower
buy an echo or a stihl... poulan rates this motor for 40 hours of use and then it is done.
head bolts came loose on mine piston slap wore out jug ring and piston. don't want to spend 40d on parts to repair a 100d unit
Posted on Nov 16, 2009
Poulan blower PPB430V will not start. New coil(set at 10) new carb kit. new plug. (plug wet when cranking) unhook kill switch, get good spark,check head bolts, Yet, Blower will not start,not even make an...
The plug gets wet and the unit has good spark? That only leaves you with two things....fuel and compression.
Dump it just be safe and mix up a batch of totally fresh fuel! You might even put a small amount of system cleaner into it to chase of water and remove gums and varnish too. Hey...if the rings are stuck it might even free them up! Kudos on checking the head bolts....they do often get loose and drop compression enough to prevent starting. Now that you have the head bolts ruled out check compression with a guage and see if you have 80-90 psi compression. Be safe and good luck!
Jul 01, 2014 | Poulan Garden
We have had our poulan leaf blower 7 moths and its been worked on 2 xs and its not starting now and has only ran one time since then im not happy with this and i wont buy another one because it is our...
Some of these small blowers end up with loose cylinder heads! If you can wiggle the spark plug and the whole head moves this may be your problem. When the cylinder is loose it wont move fuel properly into the combustion chamber because it moves up and down a little with the piston. If you want to be able to tighten the cylinder head yourself you need to make a couple holes around the spark plug opening so you can put a 3/16th hex key on the head bolts and tighten them.
The location varys but I usually see them when I make 1/2 inch holes in the cover at the 8 oclock and 2 oclock positions about an inch and a half from the spark plug. If you get the first hole wrong you can just drill another one in the adjacent corner *(its a 50/50 chance you put the hole over the bolts on the first try!) I have blowers that need a tighten every couple months and they run just fine! Check it out! Good luck and be careful!
Sep 29, 2013 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
May 05, 2010 | Homelite Leaf Vac Attack
Return spring poulan fl1500e leaf blower failed took it apart and reset it there are two short screws in the bunch need to know where they are placed there doesn't seem to be any thing obvious that is...
THAY GO ON THE LOWER BOTTEM ON THE SIDE FYI IF YOU PUT LITTLE WASHERS BETWEN THE MOTTER AND THE CASE WERE THE 4 BOLTS THAT HOLD THE MOTER TO THE CASE THAT WILL FIX YA UP
Sep 30, 2009 | Poulan Featherlite Gas Blower, with Low...
Gap setting poulan wildthing blower
Dec 06, 2008 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Oct 10, 2008 | Poulan Featherlite Gas Blower, with Low...
Stubborn Gas Blower
hey buddy chk that the cylinder head is loose or the gasket is blown,, thats what i found on mine after buying a new blower,, returned it no problem tho ,, you will have to manufacture a tool to tighten one of the bolts and also use locktite on the bolts so they wont backout after running ,, be sure to clean the holes and the bolts before applying locktite,, hope this helps ,,
bobby allison germantown tn
Oct 03, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
251 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
