Question about Canon PIXMA MP600 all-In-One InkJet Printer
Have a cannon mp 600 printer with error code UO43
I just replaced yellow and magenta ink.The error code says cannot recognize magenta carridge.
    Genius:
  • 1,847 Answers
Reinstall the cartridge, clean the print head with a cotton and little alcohol. and then retry
Posted on Dec 06, 2008
    Sergeant:
  • 399 Answers
Remove all the cartridges.then shut off the printer .then also remove the power wire of the printer from electric outlet.then wait for 2 minutes.then reconnect every thig as it was and check out.
  • Canon Master
  • 19,396 Answers
Remove the cartridge, unplug printer from power , put back the cartridge.
If that does not work, clean the printer sensor inside the ink carriage.
  • Ginko
    Ginko Dec 06, 2008
    Try the following:
    Remove all cartridges, then unplug printer power cord , Plug back the power, start the printer and put back the cartridge.
    If the cartridge is still not recognized , you may need to clean the metal sensors inside the in carriage , the ones that connect to the cartridge. Use isopropyl alcohol and cotton to clean he contacts.
    If it still does not work it may be a defective cartridge.
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
PIXMA MP 600 PRINTER EVERTNING PRINTS GREEN
Usually I see that when you put in photo magenta when it should be plain magenta.Otherwise you need a new printhead.
Jul 03, 2009 | Canon Pixma MP600 Printer
Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
9,035.4x through 9, 038:
Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
Nov 24, 2008 | Xerox Phaser 8500N Printer
Printhead errors
sounds like a carridge issue , check that the carridge can move freely and theres nothing stopping it
Oct 27, 2008 | HP Designjet 110plus nr InkJet Printer
Error Code UO43
the wire strip that connects to the printing cartrige is probably brole or just comming out of its plug
try to push the wire strip back in and see if that does any good , if not then there is a problem inside of the printer
the wire strip is broke or comming unpugged or the detection circut that sees the cartriges has failed and needs repair
hope that helps!
electech
Oct 19, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Alarm light is lit -
Ok my printer is giving me the U140 message saying that ink tank cannot be recognized. The new ink tank is Cannon (not a off brand or refill). i think it is a problem with the chip reader port inside the printer not the ink tank chip. I feel this way because if you switch around the yellow and black 8 tanks, the printer accepts them without error.. soo if it was the ink cartridge i could be able to swap the black with the magenta and it should read it.
Sep 08, 2008 | Canon Pixma MP500 All-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
217 people viewed this question
old marine
old marine
