Question about Gateway Emachine Bestec ATX-250-12E PS 250w Replacement Power Supply Part Number P/N 100744 (PSATX25012E) Power Supply
I am looking for instructions on how to replace my e-machine atx-250-12e power supply connection.
  • 24 Answers
It is important when working with computer components that you work in a static free environment (not on carpet, solid hard surface). First be aware that if you are not careful you can damage the internal circuits of your system. Getting a static discharge clip from Radio Shack is advisable, at the very least, keep a portion of your hand or arm touching the metal case of the computer to avoid static discharge.
That being said, unplug the computer and turn off the switch located on the back near the power supply. If there is not a switch then proceed.
Make sure all of the peripherals, Display, mouse, keyboard, etc. are unplugged from the rear of the case.
Do not use a magnetic screwdriver for any of this procedure.
Locate the screws that keep the case access panel attached and remove them. Locate the power supply within your computer case.
Remember to keep one portion of your hand or arm touching the metal portion of the case.
Remove all of the power leads that are coming from the power supply and going to all of the internal devices such as DVD drives and hard drives. Also, locate and remove the Motherboard power supply plug (there may be more than one) and remove them. Take note of how they are attached to the devices, most have some sort of retention device that holds them secure, do not break this device.
Once all of the power leads are disconnected, locate the screws on the back, outside of the case that are retaining the power supply unit itself. There should be 4 or more screws. Once removed lift the old power supply from the case and place it to the side. Make sure you retain all of the screws that you have removed, you will need to put them back.
Take the new power supply unit and place it into the space that the old unit occupied. Align the screw holes and put the screws back into the rear of the case to hold the unit secure.
Plug all of the power leads back into the supply just the opposite of the way you removed them, starting with the Motherboard power connection.
Double check all of the connections and make sure any wires will not interfere with any moving parts such as fans.
Put the access cover back onto the case and put the screws back into their original places.
Plug in all of your peripherals and make sure the switch on the back of the power supply, if any, is in the on position.
Power up the computer.
Posted on Dec 06, 2008
    Novelist:
  • 171 Answers
They're pretty much all the same.
open the case. pull the 20/24 pin power plug and optional 4-pin power plug out of the botherboard. Remove power plugs from fans, hard drives, cd drives, etc.
unscrew the four screws anchoring the power supply to the case. Slide out the power supply. Put a new one in it's place, the screw holes will line up. Then reconnect the power cables just like they were when you removed the old one and boot 'er up.
All you have to do is make sure the wattage rating of the power supply is higher or equal to the old one. Your old one is only 250 watts. You will have to search VERY hard to find one that low, so don't worry.
E-machines doesn't make particularely powerful desktops so you won't have compatibility problems. Almost EVERY atx psu on the market will work.
Pin out for a dell PS-5201-8D2 power supply
Use caution, some older Dell machines used a non standard, proprietary pin-out on the 20 pin connector ALso the 6 pin is suspect. If you connect a regular ATX PSU, you will fry the MoBo. Look here
DELL ATX motherboard Power Supply pinout
Jan 23, 2013 | Dell (PS-5201-8D2) (PS52018D2) 200-Watt...
Computer has bestec atx-300-12e power supply. it
Actually no, the power does continually comes in but, when stopped, the PS is in a state that could be assimilated to stand-by - only a small side circuit is continually operational.
Jun 23, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Hp pavilion a430n power supply is blinking
Look at this photo
(http://www.atxpowersupplies.com/images/300-watt-atx-power-supply-FSP-ATX-300GU-350w.gif)
Did you connect the p4 atx 12vx1 plug?
You may also need to connect the aux x1 plug on some models.
Mar 08, 2010 | HP Pavilion a430n PC Desktop
Is there a comptable power supply to replace FSP250-60HEN
Although ATX power supplies conform to various specification guidelines, there is not, unfortunately, a standard ATX power supply. To find a suitable replacement power supply for your machine, we would recommend that you have the following information to hand when making your purchase:
- You will require a PSU with a 24-pin ATX connector, SATA power connectors, and a 4-pin 12V motherboard connector
- Make a note of the wattage of your existing PSU
- Make a note of the external dimensions of your existing power supply
- Be aware that your PSU has a power connector for speakers. Most PSUs do not have this, so you may need to purchase a separate power supply for your speakers.
So it is a slight variation to a standard ATX power supply. If you are not using the speaker power off the power supply, then any standard ATX power supply will work for you
Feb 20, 2010 | Computers & Internet
Can an ATX-300-12E be used in place of an
I think it wont be a problem as long as both pwoer supplies are of same type e.g both supplies are for P4 sytems
Feb 11, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
E Machine ATX 250 -12E replacement PS
With emachine MOBO's you have to make sure you plug in the 20 pin plug from the power supply to the mobo. Also make sure all hard drives, cd/dvd roms, floppy drives, etc are turned on. Make sure the red switch on the PS is set to 115. Make sure the PS is plugged into a known working outlet. Make sure MOBO is properly in place with all grounds/screws in place and nothing metal near or touching board which may short it out.
You can review the E Machines PS replacement guide here for further instruction.
Good Luck,
Jesse
Jan 11, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
Upgrade for Bestec ATX 300 12E
Hipro- HP-P3527F3W
is the replacement for Bestec 300W
Dec 11, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
I have an old e machine 500 (origional operating system was windows 98). I am replacing the ATX switching power supply , 230 wat, model lp6100a. My problem is connecting it. I know all the connectors...
The old AT power supply that these old computers uses has two six pin socket connectors and these are different to the ATX connector.
You cannot buy these power supply now, most likely you might find one/computer in a junk shop.
If you have electronic knowledge you might be able to cut off the connectors from the old power supply and connect it to the ATX power supply and modify the ATX power supply so you can switch on the power to the old computer. The old AT power supply uses a mains power switch whereas the ATX uses low voltage to turn on the power supply.
Good luck & have fun.
Nov 29, 2008 | Powmax 400 Watt ATX Switching Power Supply...
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Gateway Emachine Bestec ATX-250-12E PS 250w Replacement Power Supply Part Number P/N 100744 (PSATX25012E) Power Supply Logo
129 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
