Question about LG VX8300 Cellular Phone
My bluetooth headset worked with my Razor but I got a nwe phone and it will not "locate" the old headset, I was told it would be OK with it.
If the phone is old, then you might have a different version of bluetooth and the headset isnt compatable with it.
Posted on Dec 07, 2008
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
How do i pair the BT350 with my razor?
First make sure the headset is off. The press and hold the answer/end button until a solid blue light comes on. Then make sure the bluetooth is activated on the razor and go into the razo menu and use the discover or add bluetooth device. Your phone will then locate the headset and ask if you want to pair/connect with it and click yes. Then you will need to enter a pass key/pin of "0000". After this your phone should automatically pair with the headset.
Nov 11, 2009 | Jabra BT350 Bluetooth Headset Headset
Connect motorolah680 to my motorola razor
go to headset and press it and hold it until it starts blinking then you go to your phone and then go to your menu and find tools press ok then you go to bluetooth and press ok then press add a new headset and it will search for your headset repeat until it finds it
Aug 26, 2009 | Motorola Mobility H680 - Headset -...
How do I use motorola bluetooth H500 with razor phone?
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your bluetooth headset pops up on the list, highlight it and press ok to connect.
your cell will then ask permission to bond with the phone, select yes. It will then ask your for a pin. The pin will be 0000.
Dec 26, 2008 | Motorola Mobility H500 Headset
Bought a Jabra BT135 and lost instructions to install, please help
1. ok when the headset is off keep your finger on the botton until it goes blue (stays blue)
2.when gone solid blue search on your phone for bluetooth
devices and you should find it
3. then it askes for the pairing key type in 0000
4.when you play music while bluetooth hedset is on and bluetooth is on it should play in the headset
Jan 22, 2008 | Cell Phones
Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Nov 30, 2007 | Jabra BT350 Bluetooth Headset Headset
H700 unable to pair up 'service not supported'
The term "service" refers to other types of services supported by bluetooth technology like keyboards, mice, etc. There's a lot more than just headsets now. I suggest checking the bluetooth options on your phone to see if there is a refresh service or other option....there is one like that on my blackberry that I once had to use to solve a similar issue. Have you tried disabling bluetooth, rebooting phone, enabling bluetooth, and rebooting phone before pairing? Also, look to see if there is an encryption on/off option on the phone...this could be causing an echo in either state due to interference...try switching encryption on/off. Also, check your update options on the phone, you didn't say which kind of phone it is but some can get firmware updates that may be needed for bluetooth to work well. Finally, you may get results by deleting the device on the phone and re-adding it thru discovery.
Jun 23, 2007 | Motorola Mobility H700 Wireless Headset
I cant scan phones using my bluetooth.
reset your blue tooth , pair it agian with your phone. remove all other blue toohts and pair it again. i hope that works .
Feb 17, 2007 | Motorola Mobility Razor Behind-the-Head...
LG VX8300 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
