Question about NEC PlasmaSync PX-42XR3A 42 in. HDTV-Ready Television
Can you connect cable tv to model #PX-42XR3A Serial #510023092 ?
Hello
I bought a used 42" plasma model #PX-42XR3A Serial #510023092 and I cant figure out if its possible to connect cable tv to this type of monitor. Please advise.
Thank You
Rob
5 Suggested Answers
SOURCE: nec 42'' plasma
Try holding down the 'INPUT SELECT' button, then press the power button on, on the tv at the same time.
Posted on Jun 05, 2008
SOURCE: Remote for an NEC PX-42XR3A......
hello,
i have brand new remote for this model from nec company.........and 2nd you can buy yourself from company call this number and let them know your model they ,ll send u remote number is this 800-836-0655 original company website is this www.necdisplay.com
have great day let me know if u get it
thanks
Posted on Nov 07, 2008
satavlad
  • 405 Answers
SOURCE: No signal with NEC plasma PX-50XM4A
You were right when you called it a monitor, it is a monitor, which means no tuner. To be able to use it as a TV you will need cable box or satellite receiver or something that has a tuner in it.
Posted on Dec 02, 2009
pabloloco
  • 2335 Answers
SOURCE: NEC PX-42VM3A 42" Power problem
I have read that this has been fixed with little more than a hard reset. This means just unplug your set for 10 minutes or so and let all the power seep out of the boards and capacitors, then plug it back it.
If that didn't fix it, your unit needs servicing. If you are handy here are some troubleshooting steps:
Check the fuse at Y-Sustainer pcb.
If blown do not replace. Look instead at scan converter boards. They are connected between y-sus & plugs from display (left side with face down, back open). Look for signs of 'burning' at upper and lower long boards. If any imperfections are found, replace all three boards: Y-sus, up & low scan.
If fuse was okay, check power supply for bloated capacitors (big board in middle of set).
I hope that helps.
Posted on Apr 19, 2010
eagle338
  • 4889 Answers
Yes the clicking noise does confirm a power supply related issue. The clicking noise is caused by the relay switches turning themselves of due to over load of certain circuits or it was not reset after a previous power surge. Rest the tv by unplugging the set from power supply, hold for 2 minutes and plug it back in. See if the problem persists and let me know.
Sai.
I have @ panasonic plasma display model TH=50PHD7UY serial YH5120189 and my question is how can I connect cable tv in to because does not have the connector on back?
Hello
Your TV has no direct cable connector. You can connect it to cable via converter using SERIAL (D-Sub 9pin [RC 232] type connector wire from converter to your TV. It is designed so. High Density D-Sub 15 pin connector is used to connect this Tv with computer. OK.
Jul 21, 2011 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
ESA plasma TV model pdp 4294lv1 does not work
my esa plasma tv model pdp 4294lv1 has sound and i can switch the tv channels, but the color is blurrier
Jul 22, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
hello,
thanks
Jun 05, 2008 | NEC PlasmaSync PX-42XR3A 42 in. HDTV-Ready...
42 ' PLASMA TV MODEL NUMBER P42LV6-T1
Haier for sure recognizes the model. It's been a problem since produced. To correct the problem you'll need an upgrade kit. I'll attach the upgrade instructions and part number for the kit. Try resetting back to factory specs as noted at the bottom of instructions. Follow the procedure to a "T" when you see two menus pop up use the one on the right. Good luck! http://service.haieramerica.com/documents/SB-TV-0003.pdf
May 28, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
No sound from daewoo 42" plasma
This particular model doesn't have internal speakers. It has two removable external speakers mounted on the left and right side of the tv. If you didn't get the external speakers with the tv, you won't have sound unless you use a surround sound setup.
May 23, 2008 | Daewoo DTS42 42 in. HD-Ready Plasma...
I need a Remote for NEC Plasma TV Model PX-50VP2G
www.replacementremotes.com should have the remote. Just enter the model number of your set in the search box
Apr 01, 2008 | Televison & Video
Projectile motion
Dear Sir,
I have NEC 42vR5 HW Plasma monitor, this plasma goes off with in 1 Minute, pls. give solution
thanks
pramod
Feb 24, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Connecting plasma tv to pc
You need to either connect to the TV the cord that your computer monitor would connect to or have a video card that supports S-Video and the appropriate cables S-Video and RCA audio out cables for either.
Then you must select the appropriate input on your TV, such as VGA or S-Video (and audio in.) .
Let us know how you make out.
Feb 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
NEC PlasmaSync PX-42XR3A 42 in. HDTV-Ready Television Logo
Top NEC Televison & Video Experts
Brian Sullivan
Brian Sullivan
Dave Naylor
Dave Naylor
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
