Question about Whirlpool GH5184XPQ Microwave Oven
We have a whirlpool GH5184XPS-4 microwave that we are getting an F7 error on. We removed control panel and parts of the board were scorched. we resoldered in loose parts still have smae problem
  • Mike In iL Jan 23, 2009
    We have the same F7 diagnostic... the unit shuts down. There is a slight pungent smell sometimes. We notice that the problem occurs in the winter...
    particularly if the temperature outside is below zero. This model vents to the
    outside. The unit is mounted on an outside wall. The food does not cook as well or as fast. If we turn on the exhaust fan, the problem sometimes goes away. The unit is only 2 years old.
  • Whirlpool Master
  • 9,098 Answers
From the technical sheet usually located behind the control panel or grille:
F7 Power to magnetron interrupted
1. Check the door, hinge and cavity front alignment. Adjust as needed.
2. Check the operation of all interlock switches.
3. To check the over-temperature protection for the magnetron, unplug microwave oven or disconnect power.
4. After 40 seconds, check to see whether this solves the problem.
5. If this solves the problem, check the cooling fan for proper operation or blockage.
6. Unplug microwave oven or disconnect power.
7. Check resistance of the magnetron thermostat. It should be close to 0 ohms. If necessary, replace magnetron thermostat.
8. Check that the control cable to the 1100 watt inverter is correctly connected to plug P2 on the display PCB. If necessary, adjust or reconnect.
9. If interlock switches operate correctly, replace 1100W inverter.
10. If problem persists, replace electronic control.
11. Plug in microwave oven or reconnect power.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 07, 2008
How CAN i TEST MY MICROWAVE?
Most common cause of an F7 code on these models is a bad inverter or magnetron. Generally it is best to replace both the magnetron and the 1100 watt inverter board at the same time, since a bad magnetron is usually what burns out the inverter board.
Jul 24, 2014 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
Code f 7
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. It should cover an F7 error code.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This may help:
F7 Error Code On Microwave Ovens With Inverter Board
MODELS: GH9177XL, GH9185XL, MH9180XL, MH7155XMS, & KHHS178L for example
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Whirlpool Microwave Ovens
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
May 27, 2012 | Whirlpool Microwave Ovens
Whirlpool GH5184XPS Microwave Oven F7 error, trips circuit breaker
Check the high voltage capacitor, it normally shorts, "discharge with screwdriver" unhook one side and set meter to ohms. Check high voltage diode tied into one side of the capacitor, "unhook from chassis ground" set meter to ohms and check for short, sometimes cracks, "must be replaced" If the diode is open meter does not have enough forward bias to check.
Apr 01, 2012 | Whirlpool Microwave Ovens
I have a that microwave gh7208xrs that shows a error code F7 HVSMPS feedback
The controller is not getting the high voltage switched-mode power supply feedback signal.
Sometimes this is due to a defect on the HVSMPS (inverter) or a bad connection from the HVSMPS to the controller.
Due to the voltages involved, I do not recommend that an inexperienced person attempt to troubleshoot an inverter.
In the event that you or someone you know wants to look into it, see these safety warnings first.
It tells you this:
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control
board.
8. Check wiring to the 1200W inverter and control system. See "Checking
Inverters."
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
I'd suspect 6 through 8 first.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jul 08, 2011 | Whirlpool GH7208XRS Stainless Steel 1200...
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Whirlpool gh5184xps-4
type in the same info you just typed, in your browser and see what happens.
Dec 07, 2008 | Whirlpool GH5184XPQ Microwave Oven
F7 Error
This is schematic:
http://www.servicematters.com/docs/wiring/wiring_main.htm
But your correct model # is: GH5184XPS4
interrupted
blockage.
Dec 06, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool microwave oven
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It says:
If for some reason your tech sheet is not there, you can download it here.
We regularly repair control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 30, 2008 | Whirlpool GH4155XP Microwave Oven
Whirlpool GH5184XPQ Microwave Oven Logo
1,495 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
