Question about Symphonic SC3813 13 in. TV/VCR Combo
TV keeps turning off after 30 seconds
It was working fine and i put a VCR tape in and it turned off in about 30 seconds. I turned it back on and it kept trying to eject itself (without me pushing eject) and after 30 seconds turned off. We finally got the tape out. It turned off again. When turning it on it tries ejecting when there is no tape in and it goes thru the ejecting process and turns it self off. This all happens in about 30 seconds. I have tried going to the menu, but i only have 30 seconds and by the time i get anywhere, it turns off. I have tried pushing stop and other buttons. Nothing happens.
  • Anonymous Nov 16, 2007
    Same problem, no other fixes?? Old TV not worth much..
    Genius:
  • 1,139 Answers
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Posted on Sep 06, 2007
  • Europa76 Nov 13, 2010
    Ah, yes. Symphonic. This TV brand is possessed I swear.
    A solution:
    One thing I tried that worked was seeing if I could put in a tape. If something seemed to be blocking it I would get something long (a flat butterknife in my case) and push back this little metal "switch" on the right side that is just barely above the bottom part of the metal holder for the tape. The Tv has to be on when you do this but be VERY CAREFUL. Do NOT touch anything else with your tool, especially the things below the tape holder! This stuff is extremely sensitive.
    Now this little metal switch will be able to be pushed back. What you have to do is keep pushing it till the metal tape holder moves down. What this switch does is signal the tv that there is a tape being inserted in. Now because you don't have an actual tape inside it's going to start getting stuck.
    (When you keep hearing the last sound the VCR makes after you put in a tape that means it's stuck). When that happens right away press the eject button. It will pop the tape holder back into it's "empty spot". Your Tv has finished a task, so it should stay on and function normally after that.
    (By the way I wouldn't recommend taking APART your Tv. That is extremely dangerous! If you have to end up taking it apart it's better to take it to a TV repair specialist)
    Yes this question is 3 years old, but this TV brand has given me so much hell I felt it necessary to give actual good advice on it. :)
My tv keeps going into stanby mode and also swaps picture sizes
Posted on Aug 11, 2008
I had the same problem, I had my brother check it out and for me it was a small piece of yarn down in the VCR cubby hole..heheh...anyway...works great now and I hope it's as simple as that for you.........Valerie
Posted on Feb 26, 2008
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
Dec 24, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Magnavox TV/DVD/VCR combo keeps turning off
So after calling a tv repair guy and listening to him tell me about how it is probably something to do with the transistor and it will cost me about 150 dollars to fix ( which I could buy a new tv for that price since it is only a 19 inch) I decided to look online at this issue of turning off after 5-10 seconds. I read about it being an issue with the VCR sensor, so I don't know about it being some LED that you have to replace because I just messed around with a VHS and moving the little white bar thingy on the right just inside the door for the VHS around a bit, and Voila it started working right again. I think maybe my son tripped something by sticking things in there and whatever I touched fixed it. So my advice is to just stick a VHS in and take it back out a few times and play with a few things inside and to the right. It didn't take long for it to work for me.
Jul 23, 2009 | Philips Magnavox 20MC4304 20 in....
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
My Tv is turning off by itself
unplug and let sit for a min then plug back in
Jan 01, 2009 | Televison & Video
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Power problem
Has this just started happening? What did you do just before this happened? You need to supply much more information, we are not mind readers! What's the make and model, this ain't a generic problem!
Oct 06, 2007 | Quasar VV1309 13 in. Combo
VCR Tape will not play, it keeps ejecting
I have a similar problem. It takes 3 or 4 times to get my Sony VCR to accept a tape. Once it does, everything is fine, until I turn it off. Next day, same trouble. I tried several tapes and brand new tapes. No difference. I have opened the cabinet and used alcohol to clean various stuff, no change.
Feb 02, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Symphonic SC3813 13 in. TV/VCR Combo Logo
477 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
