I have the 4 port Linsky Router.I have a Sony laptop connected to a Sony wireless routerI also have a movie download box. When I connect both to the modem separetely,bolth the laptop and the mvie download box work great. But when I split the signal using the Linsky router to the Sony laptop and movie download box,neither the laptop or the movie dwonload box can get a signal from the internet. Sincerely,Tony from Philadelphia. asalmieri@verizon.net
    Novelist:
  • 171 Answers
This is because your wireless router is a router, and your linksys is also a router. Both are attempting to do routing, and they're colliding with each other.
Go into your linksys router's settings, and set it's IP address to have the SAME subnet mask as your wireless router, (The third number in the ip address has to be the same)
e.g. if your wireless router is 192.168.0.1, make sure your linksys is 192.168.0.2
if your wireless router is 192.168.2.1, make sure your linksys is 192.168.2.2
After that, turn OFF the dhcp server on your linksys router (do this in the linksys config page).
After that, plug the LAN port of your linksys to the LAN port of your wireless router.
Your linksys will now be acting like a "Switch" which is an extension of your network. Voila!
Posted on Dec 06, 2008
Linsky Router Login Page
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 20, 2012 | Computers & Internet
Linsky router has been connected for a year and working fine but within the past 24 hours even though the signal is strong for connection it will not permit us to go wireless on the laptop or son's XBOX...
can you access the Linksys page while on wireless even if it gives you page cannot be displayed error when you browse?
try to do a hard reset on the router and reconfigure your wireless connection. just press the reset button for 10 seconds to reset it properly.
Jan 27, 2011 | Linksys Wireless-G Broadband Router
Error 12007 on hp dv 1000, no wireless capability from linsky router, says connected but won't connect to IE8
Error 12007 qrcl\x22qv{ng? amnmp8!dd22229 \x3C>go\x3Capkvkacn>-go\x3C>-qrcl\x3C\x22qkel\x22md\x22cl\x22wlqvc`ng\x22q{qvgo\x22vjcv\x22kq\x22v{rkacnn{\x22acwqgf\x22`{\x22korpmrgp\x22ocklvglclag\x22md\x22vjg\x22amorwvgp,>-r\x3C\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22\x22>r\x3C>qrcl\x22qv{ng? amnmp8!2229\x22dmlv/qkxg83:rz9 \x3CQ{orvmoq8>-qrcl\x3C\x22Gppmp\x22");//--> is caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer. You need to go online and download the windows repair tool and it will fix the problem.
Jan 26, 2010 | HP Pavilion dv6000z Notebook
Login on to linsky
Under this condition you should connect the linksys router physically by LAN cable and that try to get connected with and reconfigure it properly as per your requirement. If still unable to solve the problem than kindly reset the unit to factory default by pressing the reset button.and that try to get connected with and reconfigure it properly as per your requirement.
Dec 23, 2008 | Linksys Wireless-G Broadband Router
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Can you put linsky router on your laptop
the picture of the device shows an adapter not a router, but in any case,you can put this on either a laptop or a desktop as long as you have a usb port available.
Sep 28, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Linsky wireless connection
Yes, you can still manually configure the router to setup a wireless security so that no one can use the wireless illegally and download files. What is the model no. of your router?
Jul 22, 2008 | Linksys Wireless-G Broadband Router
Router problems
Did you enable the wireless on the router?
Jan 08, 2008 | Zyxel Prestige 334 Router
Linsky password
If you're after the default userR/password to log in to the admin-intaserface on the router it's usually ussername=root and password=admin
If it's the wep-key it's asking for there are software that can fetch this from your computer, but it's probably just as quick and easy to change the wep-key in the router and set up your writeless computers with that key.
Nov 27, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
