Question about AMD M863G (M863G15CV22ARV000) Motherboard
M863G wiring I need to know the wiring of a M863G motherboard. Especially the front LED for power and HD along with the reset and HDD led on the front of my comuter. I have the wires but the board lists numbers only.Located in the Bottom Right Corner.
  • 1 more comment
  • erikeuvrard Dec 08, 2008
    Quick question.
    I have a bad power supply. It is a 300W. All I have in stock is a 500w. Can I use this with this motherboard?
    m863g.
  • sabadannalis Jan 30, 2009
    I NEED TO KNOW THE WIRING WHERE TO PLUG IN RESET BUTTON,HD,LED JACKS I ONLY SEE NUMBERS
    WIIRING
    Genius:
  • 1,061 Answers
Everything is here at website for your boardhttp://pcchipsusa.com/prod-m863gv51a.asp.RICHARDM69
Posted on Dec 06, 2008
  • Desktopsbyduck-Computers
    YES YOU CAN REPLACE THE 300W WITH A 500W.RICHARDM69
Where to fix the power switch,power led and HDD led
There will be a set up pins pointing up from the mother board - usually along one edge, and the cable you have that come from the switches / LEDs on the front panel will fall in the general direction of those pins. If you look very carefully at the writing next to those pins you will see words like PW = power switch, HD LED = Hard Drive LED lights, SP = speaker and so on. You really should visit the motherboard manufactures web site, find your board and download the manual which will show you as well as tell you how to connect up the wires. LET this be a lesson to you! Write down or draw a picture BEFORE you start pulling wires out!
Dec 22, 2013 | HP Vectra VL400 P3 Skt 370 Motherboard...
I dont know how to fix the Front Panel Audio Connector. And I dont understand what is ATX power switches. I'll tell you what wire i have: H.D.D. LED, POWER LED +, POWER LED -, RESET SW and POWER SW....
Hi!
You have to make make the four Front Panel Connection as shown below: -
(IDE LED is the same as HDD LED and Ground means negative '-')
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
May 31, 2011 | ASUS P4VP-MX Motherboard
Pulled off front cover. three sets of wires came off. need to know where to reconnect. white/red wire HDD LED, white/green wire POWER LED, white/black wire POWER SW
Hi. You may want to check your motherboard for this wires to connect to, First, check your motherboards manual and look where the FRONT PANEL is located, then on the front panel or in the manual itself it will tell you where are those wires should be connected to. If you dont have the manual for your motherboard search it on google and do the same, and if still you coudnt find it over the internet then just look closely on your motherboard and look for the words HDD LED, POWER LED and POWER SW, usually those words or the FRONT PANEL is located on the left side bottom part of your motherboard. Hope This Helps
Jun 09, 2010 | E-Machines T3302 PC Desktop
I do not which pin is for the wire power, reset, HD led, - p ledand positive P led.
E 210882 Motherboard power swicth, rest swicth, HDD led, - P led and positive P led pins
Mar 21, 2010 | Dell (E210882) Motherboard
Setup wiring led,hd
you can find it here...
this a manual...
the sequence of the wires are power button,reset butoon, power led hdd led..
it is located on the lower right potrion of your motherboard...
try to short ifrst the pins to make sure where is the power button..if you already found it just follow the sequence i said...
Feb 10, 2010 | Intel D850MV Motherboard
Wiring front panel
if you go to this website
http://www.foxconnchannel.com/support/downloads.aspx
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
Apr 13, 2009 | Foxconn 760GXK8MB-RS Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Front panel pin layout. I need the front panel pin layout especially for the HD IDE active LED.
Howzit
Trial n Error is your best bet on the control pins panel there are two rows, with the power plugged in,with a screwdriver touch adjacent two pins together at a time starting with the top row then the bottom row, when you touch the right two pins your motherboard will power-up, then place the power-switch plug onto those two pins (the writing on the plug facing innwards toward the mainboard) the two pins for the reset switch and 99.9% of the time located directly next to the power switch or directly above the the power pins on the other row. For the LED lights you will have to just try the different pins and the Power LED will remain on as long as your mboard is on, but to find the LED pins for the Harddrive you will have to plug in your HDD and then when it powers up try the pins and the led for the HDD will flicker on-off, that would be the correct one. Dont worry your mboard will not be damaged by this in any way. Goodluck and let me know how you go. Thanks
Regards
Oct 27, 2007 | Iwill VD133Pro Motherboard
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
AMD M863G (M863G15CV22ARV000) Motherboard Logo
331 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
