Question about Vizio L30WGU 30 in. HD-Ready LCD Television
Need to get to channel 3 goes to 4 ,16 ,17 How to I get there?
I need to get TV to channel 3 it goes to 4, 16,17 not 3
  • 10,594 Answers
Please perform Auto Tuning / Auto Search ( in tv menu) to feed all channels data again in TV memory.
Posted on Dec 06, 2008
Cable channel source goes up from channel 3 to higher channel?
First to check your cable resepction then replace your tv tuner same number your tv channel mistunes
Jun 09, 2015 | Prima Televison & Video
We have no remote. Is there a way that I can get my tv to stop on channel 3? It just goes from channel 2 to channel 4 and does not allow 3 to come on -- skips right over it . I just need to use it for a...
it simply means that channel3 has been set to skip/go to the tuning menu and select manual search.select channel position3 and cancel channel skip function.
Oct 05, 2013 | JVC AV-32F703 32" TV
Can't get the TV to go to channel 3. How do you get the TV to run the channels. It goes from channel 6 to 123.
You need to have your television plugged in to the cable, then auto-program your channels. This option is located in your menu. If channel 3 exists, the tv will find it during the autoprogram.
Mar 14, 2011 | Samsung Televison & Video
I have a SV2000 TV and DVD combo no remote and need to get on channel 3 for the cable to work. ITs on channel 2 then goes to channel 7 and up .Ineed to get it set on Channel 3 and no setting button on tv...
Try going to a store like Walmart and buying just a universal remote and try different remote codes listen in the instruction manual until you can access the menu and do a channel scan. That's really the only solution I can think of.
Feb 09, 2011 | Funai EWF2004 20" TV
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Program satelite or cable
you are not specific as to programming cable or satellite .if you have cable tv with a cable box there is no need to program tv channels.the tv should be left on channel 3.check the back of the cable box & tv it may also be connected thru rca/s-video or componant cables meaning the tv should be on a line in/source ,or video input. for a tv without a cable box
you can do the auto or manual programming. no need to be on channel 3. if you have satelllite tv you need the box to hook up to your tv.you cannot bypass this box unlike cable tv.also check the back of the box for the other possible connections
good luck
wg
Jan 28, 2008 | JVC AV-27D202 27" TV
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
760 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
