Question about Dishwashers
Main sink and d/w did not drain. Used plunger heavily. Did not work. Had main line jetted out. Now sink drains but d/w still does not. Older model Kenmore #1661590 Thank you
  • 706 Answers
Hello playultimate,
I am assuming that your dishwasher drains either directly into your sink or through a garbage disposal as part of your sink. Regardless of which method is used, you need to verify that your dishwasher drain system is funcioning properly so.. make sure your dishwasher drain filter is free from debris.. if you are still having a problem could be the pump is defective or clogged with food byproducts, the lines into and out of that pupm are clogged of the drain hose itself is clogged or pinched.. Once you have cleaned your drain screen inside the dishwasher, .. try cycling it withour dishes to see if you get a reasonable drain flow .. The key is to identify if its a clog/restriction or a bad pump... Hope some of these ideas will help solve your problem.. Get back to me if you are still struggling..
Posted on Dec 06, 2008
Sink backed up went in dishwasher. Then it drain in sink. Fixed sink stopped up but washer keeps draining but nothing in drain
Your post is a little confusing but I'll try my best.
First, it sounds like you fixed the sink problem and now have a dishwasher problem related to the backup.
I would take the drain line off both the sink and the dishwasher and clear anything that got stuck in there while fixing the main sink drain. It could have had something plugged into it by using a plunger on the sink.
If you have any standing water in the dishwasher, pushing the cancel button should activate the water pump and you should see the water drain into the insinkerator, etc whilst hearing the pump. If you hear the pump and see no water draining but still have water in the dishwasher, you have a clogged line. If you don't hear the pump, your pump might not be working or the cancel does not activate the pump.
Jan 17, 2018 | Dishwashers
Shower in basement is backed up. Wondering if it's because a floor drain is covered up.
sounds more like the drain line is clogged between the shower and the main stack, and shares venting and drain with your kitchen sink. Have a plumber run a drain snake down from your kitchen drain (after the 'P' trap ) to clear the line. A covered over floor drain should have no effect on the back-up.
Oct 31, 2014 | Plumbing
I have a glass bowl sink in my bathroom. The pop-up drain is stuck in the down position and will not release. How do I fix it??
You'll need to access back side of sink bowl and locate drain mechanism, most likely either the plunger rod has loosened up from clevis rod or clevis rod is positioned to far in towards drain line causing it to bind. Check diagram for assistance in locating parts.
Is the plunger rod tight or loose? You can also loosen clevis screw and see if the plunger rod will slide freely. If it does try moving the horizontal pivot rod up and down, while doing this you should she your drain plunger moving up and down. If it does not then most likely will need to replace plunger mechanism by removing the retaining nut on the back side of the drain line. This will allow you to disassemble the actual drain plunger but I would definitely start with the mechanism of the stopper and clevis where it attaches to horizontal rod.
Sounds like a simple binding. Always be sure there isn't anything stored under your sink which could be causing the problem. Sometimes the most obvious is the last thing we look at.
Good luck.
Aug 16, 2013 | Pegasus Technologies Pegasus Clear Round...
Main sewet line on 2 story hom
Well the main will be in the basement first snake the drain that's pluged but would use a plunger first chances are your haveing a problem in a bathroom drain if so remove the plug get something thin chances are full of hair
Jul 07, 2013 | Plumbing
Garbage disposal and possible clogged drain
plug the one side of the sink so as to create a sealed enviroment for the plunger to work weffectively ... plung the open side ..
If this does not work , try running a metal coat hanger thru the outlet at the disposal exhaust line.
Mar 25, 2013 | Electrical Supplies
The cable system on the pop up assembly is not working. lifting up or pushing down on the stem does not engage the plunger(in the sink drain).
One of two things can be wrong.The first is the drain plug itself has become disengaged with the plunger inside the drain line. You can check this by pulling up on the drain stopper itself, if it comes all the way out then all you need to do is to reinsert it and give it a little twist to get it reseated on the plunger hook. The other may be the drain handle on the top of the faucet may be disconnected from the rod. Open up the doors underneath the sink and inspect it. The rod should go down and the plunger handle should connect to the rod via a bent metal clip. Ensure it is in the correct position to activate the handle in the drain pipe when the top is pulled up.
Nov 29, 2010 | American Standard Swan 4 In. Bathroom...
How do you secure the overflow plate
I think you're referring to the drain stopper in your sink? They have to positions, one drop in so you can remove it easily to remove debris, or the other position it is engaged in the lever assembly that raises and lowers it. Loosen the nut on the drain line where the lever enters the drain (under the sink) retract the lever slightly, lower the plunger with the hole aligned to the lever. Re-insert the lever and test that it raises and lowers the plunger. Then try to lift the plunger. If you have engaged the lever into the plunger then it will not come out. Re-tighten the nut.
Jul 04, 2010 | Moen 103459 Drain Pop-UP Plug
We have a kitchenaid dishwasher KUDK03FTSS. some type of clog. draining into the sink from the overflow. what should we look for and where?
If this is an old installation and the unit has been working then the problem is with your house-sink drain.
Dishwashers either connect to your disposal unit or to the drain directly. Usually if you have a clog with a disposal unit in the line then it backs up into the sink through the main drain. You say from the overflow.
Look under the sink and find the point where your dishwasher connects to the main drain. Open the connection and check for a clog just below the connection point. This is the most likely cause of your problem.
Good luck.
Please rate this answer if your find it helpful.
Mar 21, 2010 | Dishwashers
My sink is backing up on bothe sides
Your drain line is clogged, beyond the sinks. You might be able to use a plunger to clear it. Seal off one the drains and use the plunger in the other. After you get it cleared, run pure hot water for a few minutes to melt the junk out of the line. When using the disposer, use cold water only, NEVER hot. If this doesn't get your drain flowing, you will have to snake the drain--to the main drain.
Oct 04, 2009 | Home
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
