Question about Yamaha RX-V595 Receiver
Just a clicking noise
I turn on my reciever and it wont turn on it just makes a clicking noise. i checked the fuse and i think it is good but i cant figure it out. i really dont have another 500.00 to spend on a reciever. if you can help i would appreciate it. thanks
0 characters
1 Points
After turning on my reciever i get a flashing poweroff on the display. unit then shuts down
check your speaker connection. if that doesn't work check your fuse to make sure it's good.
Mar 03, 2011 | Pioneer VSX-D510 Receiver
When I power the reciever on all i hear is a click noise and it does nothing else.
Check the main fuse if it is open (blown) it will probably need output transistors MP1620 MN2488, if not it may need the main power transformer.
DO NOT use a slow-blow fuse this will cause more damage to the receiver!
Oct 21, 2009 | Sony STR-DE485 Receiver
Onkyo digital reciever has poping noise when in dolby sound
I have the same reciever, and had the same problem.  Contact Onkyo, this is a known issue where defective DSP chips were used and manifest problems with a popping / clicking sound when using surround settings.  These receivers also have a Dolby Digital input issue that can cause audio dropouts when watching cable or SAT broadcasts that encode DD using a 'newer' broadcast encoding methods.  Onkyo is covering the cost of that repair for me now, even though the receiver is 5 years old now....
Jan 02, 2009 | Onkyo TX-DS797 Receiver
Yahmaha rxz9 no output signal to sub
the part where you plug in the sub has blown or warn out over night dude get it repaired i think u need to change the fuse inside the reciever
Dec 31, 2008 | Yamaha RX-Z9 Receiver
HK 3480 sound suddenly cuts out
your fuses are blown by possible crossing speaker wire - and + together. I did this and kept turning it on but I ended up frying the unit. Check your wires and make sure that they are seperated properly. If problem continues then unscrew the shell and replace 1 or all 3 fuses (depending on what was blown) with GMA 8 amp fuses. good luck.
May 23, 2008 | Harman Kardon HK 3480 Receiver
Protect Mode
Make sure that you are not asking too much from your system by having a "heavy" bass contour, or processing externally that amounts to the same thing...accordianman
Sep 27, 2007 | Sony STR-DE597 Receiver
Wont turn on
The solution is to replace the main power relay. I ordered a replacement relay from Vance Baldwin Electronics - part RELAY DC DG12D1-0/M11 RXV2095 (V6881300). After installing the relay this morning, my receiver now stays on continuously like it is supposed to. You can easily fix this yourself in about an hour. All you need is a screwdriver, a soldering iron, and some solder.
Sep 18, 2007 | Yamaha RX-V995 Receiver
No sound coming from reciever from tv
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Jan 24, 2007 | Yamaha HTR-5440 Receiver
Yamaha RX-V595 Receiver Logo
41 people viewed this question
Top Yamaha Audio & Video Receivers Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Are you a Yamaha Audio and Video Receiver Expert? Answer questions, earn points and help others
