Question about Maytag Neptune MDE5500AY Electric Dryer
My mde5500ayw shows the 08. the start switch doesn't work
The dryer works if you do a go around. You go through diagnostics etc and it can make the dryer run. I have had 2 responses I have read, one is that it is the circuit board or capacitors on the board and the other is that it is the console and I need a new console w/membrane.
these seem like 2 different things to me. If it's the console, would that just fix the start button problem or is there a real circuit problem even though everything still works but the start button.
  • nappiecleo Dec 08, 2008
    I also have the 8.8 showing up in the display, but how do you get to the diagnostics? If it is by pressing and holding the Damp Dry button for 5 seconds, I already tried this and It did nothing. The screen display remains at 8.8
    Problem Solver:
  • 4 Answers
I think I remember that code 08 means that one of the keys on the touch pad are stuck. See my other response about finding the service papers inside the top of the unit, and it will tell you which combination of touch keys to press in order to reset the touch keypad ( Membrane). Just FYI: the membrane is the computerized touchpad, and the console is the computerized circuit board inside behind the buttons and they are connected.
My LED screen displayed 08.8 which basically means the computer circuit board is not working. I was able to find the part at a local supply store for $180.00. I installed it and IT WORKS now!!! :-)
Note: It sounds like your error code is 08 as opposed to mine 8.8. Big difference on conveying what is wrong with the machine. Oh, and the touchpad membrane I was told cost approx. $150.00.
Posted on Dec 09, 2008
Duet model GEW9200L. What does code 08 indicate?
there is no such error code on this dryer, that is likely the time left on the display... If the dryer stopped at the 8 minute mark with no error, check the door switch because it can interrupt a cycle, but will result in no error... Did you try to start it again, what happened? Whirlpool Dryer Main Control Board WP8546219
Jan 15, 2016 | Whirlpool Dryers
Hello, my dryer MDE5500AYW won't dry on a cool temperature. It is an electric dryer
You buy no parts
You diagnose the problem
to find something wrong
How about looking in the owners manual
& follow the trouble chart
I do not know about Maytag Dryers, but the washers
have a diagnostic manual in a bag under the cabinet,
they don't want you to find,your dryer may also.
Nov 20, 2014 | Maytag MDE5500AYW Electric Dryer
What causes start/pause button to work sporadically?
It sounds like the switch is getting bad, contacts in the switch no doubt have burned spots and it is hard to get a connection through burned spots. So I would say replacing the switch is in order.
Jun 21, 2014 | Maytag MDE5500AYW Electric Dryer
Maytag dyer problems
it sounds like the control board is going bad but i wouldn't buy any parts for this dryer,soon you won't be able to get parts for it,put the money into a new dryer not to mention that the neptune products is what took maytag out and now whirlpool owns maytag.you could also have a problem with one of the connections or a bad wire in one of the connections and when you move the wires it's working again and this could be from the heat,after years the wires get brittle,you could buy the new board,put it in and if it's a wire you're back to square one,but from what you say it's either a wire in one of the connections or the board.good luck with your dryer.
Nov 12, 2013 | Maytag MDE5500AYW Electric Dryer
Dryer will not start
Check to see if the door switch is working. If you have an interior light, it should go on and off when you press it. Post back your results.
Nov 20, 2012 | Maytag MDE5500AYW Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Model MDE5500AYW Maytag Neptune Dryer showing code 8.8 and won's start
the circuit in the control. you can get it at
http://www.apwagner.com/index.php?main_page=part_finder
I hope this helps.
Dec 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
243 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
