My Dell SE198WFP LCD Monitor says 'CANNOT DISPLAY THIS VIDEO MODE" OPTIMUM RESOLUTION 1440X900 60HZ. When I start my pc it runs normaly but when its going to start it says that message and cannot do anything. I have tryed changing the resolution in safe mode,and still problem persist.
SOURCE: i installed Windows 2003 on
Windows has loaded improper video adapter drivers,,you need to install correct ones
SOURCE: Resolution
1280 x 1024 resolution
800:1 contrast ratio
Thanks for posting and please rate
Sean
SOURCE: DELL E153FPf doesn't show the image
OSD Warning Messages
A warning message may appear on the screen indicating
that the monitor is out of sync range.
Cannot
Display This Video Mode
This means that the monitor cannot synchronize
with the signal that it is receiving from the computer. Either the signal is
too high or too low for the monitor to use. See Specifications
for the Horizontal and Vertical frequency ranges addressable by this monitor.
Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the
screen is blank. This could also indicate that the monitor is not synchronizing
with the computer or the monitor is in a power save mode.
Testimonial: "I have checked 4 (four) different modes: 800 x 600 @ 60 Hz, 800 x 600 @ 75 Hz 1024 x 768 @ 60 Hz, 1024 x 768 @ 75 Hz all were O.K."
SOURCE: I keep getting the following error: Auto Detect
Right-mouse click anywhere on your computer's "wallpaper".
Click Properties.
Click Settings.
Move the screen-resolution slider to 1680-by-1050.
Click Advanced.
Click Adapter.
Set the adapter to 60 Hertz.
Click OK.
SOURCE: My Dell E207WFP LCD monitor has a blank screen
Hello!
For this issue you might reconsider focusing on your CPU Tower, the way you're describing the issue, the monitor losses it connection from the computer, therefore showing the "analog input..." This is a power saving feature of your monitor. This means that the monitor is no longer a signal from your computer. Possible points of failure for this one could be, PSU, memory, motherboard or add on video card if you have one installed, best approach i could suggest is to run diagnostics- if your still able to boot the computer - Try powering up the computer, when you see the Dell logo tap F12 several times until you see some options then look for diagnostics, then run it..(this is for a DELL pc) if it fails then a possible hardware issue, if your pc still have warranty, call in for help.
Hope it helps!
