Question about Xerox WorkCentre Pro 575 Plain Paper Laser Fax
Work center Pro 575 will not communicate with PC.
Changed PC to one that used to communicate and still no go. Is there a way of resetting the machine?
I changed the port address to 3BCh-3BF and set the port to SPP. Rebooted twice and all seems to be working. Noticed the WorkCentre wakes up from Power Save mode on reboot, if this happens then all is working OK.
Posted on Dec 08, 2008
What does NGB0 mean on the activity report?
NG is shortcut for "No Good", indicating a problem. "B0" is the fault code for a communication problem, usually caused by an incompatible setting of communication mode G2 or G4 on the remote machine.
Contact the remote operator and ask he set up his machine for EECM or G3 communication mode, then retry.
Jan 06, 2011 | Xerox WorkCentre Pro 575 Plain Paper Laser...
I have a workcentre pro 575 and am receiving the message, "memory full". Nothing will print, and I hope you can tell me how to get the stored memory to print out. Thanks.
You hopefully just need to clear memory, delete phone numbers or delete jobs.
If those don't work the Main Board might be bad 160K72560
Whit
Item, Inc
Aug 17, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Winfax Pro
Uninstall winfax Pro,
Delete all related folders,
Then reinstall the programme again after reboot.
It should work well now.
Please rate this......
Mar 19, 2009 | Symantec WinFax Pro for PC
Xerox WorkCentre Pro 575 error message
Could be the tab that actuates the top cover switch is broken off.
The process unit is your drum,toner, and developer unit. It sits right under the top cover. Big black removeable cartridge.
Nov 03, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Winfax pro 9 dosen't keep program changes
If you attempt to use another user profile, that user cannot change WinFax settings because that user doesn't have write access to the proper WinFax registry locations. Log into the admin account and then change winfax settings. They should then be changed for all users
http://www.getfaxing.com/support
Apr 09, 2008 | Symantec WinFax Pro for PC
Xerox WorkCentre Pro 575 Plain Paper Laser Fax Logo
66 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
