Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Would like to know if a security locked Hdmi cable would screw in behind television
Many HDMI Inputs have a small "fixing" screw above or below (also sometimes corner, or not at all). There are some cables that have a screw built into the cable that you can use to screw the cable into this location. It only works with one location of screw, so make sure you check your unit to see if it will work.
Blue Echo Solutions, Inc. offers a product called hd EZ lock(TM) that works with most existing cables, so you don't have to replace your cable or you can purchase the cable of your choice. It works with cables up to 7/16" high x 7/8" wide (measured at the head, within 1/2" from the chassis) and works with various fixing screw distances, up to 3/8" from center of input to center of fixing screw. It also has an adhesive option if you don't have the fixing screw. See www.hdezlock.com to learn more.
There's a couple of other options available, but hd EZ lock(TM) is the only option that works with almost any cable on the market.
Posted on Dec 13, 2008
How do I unlock my TV it has key lock and I don't have a remote
Fixing key-lock on TV without a remote - television westinghouse ...
ask.metafilter.com/166214/Fixing-keylock-on-TV-without-a-remote
Sep 27, 2010 - I cannot change my Westinghouse LCD TV's channel, and it's driving me bonkers. ... The cable remote probably has a mode which causes the cable ... Plan B. is if you have an HDMI out on the cable box you could ... Note don't pay more then $8 for HDMI cables you can order them on Amazon for about $3
Are You locked Out? ' Techlore
www.techlore.com/article/are-you-locked-out
If you have a blank screen with a red key on the bottom left, simply press the (function or .... If you have the original remote (RC-A07) for Sinotec tv, then press and hold down.... I need to know how to unlock it, my fiance has managed to push a bunch of .... V-Chip is locked on a Trutech T2000-FT and we don't know the code.
Jan 29, 2016 | Televison & Video
HDMI cable does not work with Dish hd 612 box what is problem
Hi, Cheri Torres with DISH Network Customer Service here. There could be a few different reasons that your HDMI cable is not working. The cable could have gone bad, sometimes the cable is loose and you will need to make sure it is secure or when the cable was taken out of the TV or receiver it may have been accidentally damaged. What are you seeing on the screen when you have the HDMI cable plugged in? Please make sure that the the TV is on the correct input to receive the picture from the HDMI cable. You can also try to reset the DISH receiver box by unplugging it from the wall for 10 seconds. Another option you can try is replacing the HDMI cable to see if the cable has gone bad or been damaged. The last option to try would be to use the cable on a different device such as a blue ray player or gaming unit. If the cable does work on a different device then the receiver may be the issue. I hope this information helps and if you have any further questions or concerns please let me know!
Nov 01, 2011 | Akai LCT2721AD 27 in. LCD Television
No sound. just got connected to direct tv and now no sound. cannot see behind tv to know which red and whit jacks are audio in.
I would strongly suggest buying a HDMI cable and run it from your DTV console to your TVs HDMI input and this cable takes care on audio and video. This is relatively easy but get someone to give you a hand if you are limited in what you can do. You then must go into the TVs menu and make some simple choices.
God Bless
Bill
Jul 04, 2011 | Akai LCT4216 42 in. LCD Television
When i turn tv off and then back on it doesnt have volume if i turn tv off unplug HDMI cable then plug back in then turn on TV i have volume its annoying and NO ONE can figure out why it does that ...
While HDMI has been a very convenient choice for the consumer, it has also provided better security for the owners of the content that we watch on our TVs. HDMI does what is called a "Security Handshake" between the connected devices. A lot of people have to ensure that their TV is turned on prior to turning on the connected device or the security handshake fails.
Most people overcome the security handshake by using a programmable remote that turns their TV on prior to the connected devices.
I hope this information help explains the odd behaviors of HDMI.
Please let me know if I can assist you further.
Regards,
KYTechnology
Mar 02, 2011 | Philips 42PFL3704D LCD TV
Just bought an open box 32L152A-11. plugged in the electrical cord and inserted the input cable and screwed it in securely. fios box is not an "hd" so i am not i nserting a hdmi cable. i...
from what i gather you are trying to get hdtv to work with rca cables without using an hdmi cable . if this is correct then all you need is RGB cables . just like rca but they red green and blue . look on the back side of your tv , there should be a set of RGB inputs and also rca .
Feb 09, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
My RCA L46WD22 TV turns on but there is no picture or sound, just "unusable signal" message.
This is a very common problem with these models.
The problem is a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Jul 21, 2010 | RCA L46WD22 Television
Sceptre X37sv-Naga 37 HDMI port is not making contact
hd EZ lock by Blue Echo Solutions is a Universal HDMI Locking Adapter, the only one on the market. It works with most HDMI Cables and components and attaches to your component's chassis, using the existing screw above or below your HDMI Input or with the supplied adhesive. It supports your HDMI Cable from the component's chassis, eliminating stress on your HDMI Input and keeping your HDMI Cable in place. www.blueechosolutions.com
Oct 17, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Television Won't Display Certain Cable Shows
Okay,i assumed this is what you have:
HD cable box with HDMI cable connection to the Samsung TV.
Listen careful as follow:
First you want to make sure using the same HD comcast box with HDMI connection for our Samsung TV as well as your other TV.Be sure the other TV do received the missing channels from the Samsung TV.You must be SURE you have tested both TVs with the same HDMI cable with the SAME HD cable box.
Now that you have confirmed the both TVS are using the same HD comcast box and the same HDMI cable but the connection that goes to the Samsung TV are missing some channels,at this point,use another HDMI connection behind your Samsung TV and see if you have the same problem.If so,please also try the left side of the HDMI connection and see if you could get the other channels.
Let me know!
solutiondoct
Jun 15, 2008 | Samsung HP-T4254 42 in. Plasma Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
97 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
