Question about Hotpoint 4.87 cu. ft. / 138 liter Upright Freezer FZA50
Red light on not cold enouth
My freezer doesnt seem to be cold enough the red light is constantly on i have removed contents and put in my chest freezer in case of defrosting. model number is RZA50 its frost free model
regards carol
  • Hotpoint Master
  • 3,463 Answers
The red light bis indicating that the temp is too high, if you can ,turn the thermostat to a colder setting, if this makes no difference, then you have a serious problem, you will have to call an engineer.
Plz rate this solution,
Posted on Dec 25, 2008
Alarm light Westpoint Chest Freezer
is it getting cold inside .why would you want MAX temp tho turn to mid point as a startingplace
Nov 22, 2015 | Freezers
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
Red light is on all the time, wont stop running
Some freezers have a pilot light that is constantly on whenever power is being applied. If the compressor seem to run constantly, check for a bad lid seal. Also, the thermostat may at may be defective
Jul 19, 2013 | Magic Chef 5 cu. ft. / 142 liter Chest...
Compressor runs but freezer not getting cold
Have the gas checked. If the thermostat pick-up is frozen over that could result in the contents of the freezer not getting cold, but for that there would have to be a build up of ice on the sides of the freezer.
Jan 25, 2011 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
My Electrolux TC75 Chest Freezer wont even get cold
well one thing to know if the thermostat is working and if the gas is really enough to allow the unit run well.
Feb 27, 2010 | Freezers
Not cold enough?
is this a chest freezer or upright frost free fridge freezer . nead more info
Oct 19, 2008 | Freezers
Kenmore Upright Freezer Model 2539252110
constant clicking, sounds like a compreesor trying to start itself, you might geta way with replaving hte starting device for compressor, sometime s a bad compressor will burn out a starting device, checl your warr papers, most compressors had afull 5 year warr
Mar 16, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Hotpoint 4.87 cu. ft. / 138 liter Upright Freezer FZA50 Logo
759 people viewed this question
Top Hotpoint Freezers Experts
Justin Duby
Justin Duby
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
