Question about BenQ FP71G 17" LCD Monitor
Benq FP71G words fuzzy with purple
Word displayed have purple tint. Left screen panel also has purple line from top to bottom of screen.
Move away from all magnetic interference and try to demagnetize screen but still could not solve the problem.
  • 293 Answers
Don't've got a busted panel. If it still under warranty send it back for replacement of panel. If not, then just buy a new one... it's will saved you $$$...
Posted on Dec 06, 2008
My BenQ FP71G Monitor has been turned off for 2 weeks on starting it this morning I have fine colored lines that cover 1/3 of the screen on the right hand side.I have checked the cables. Have you any...
You have failing LCD panel or the 5vdc feeding the panel may be bad. Check to connection at the LCD panel T-CON board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Capacitors kit:
Aug 06, 2010 | BenQ FP71G 17" LCD Monitor
Where can I buy a logic PCB for FP71G Benq
Shenzhen VIIV Technology Co., Ltd is an expert at PCB,PCBA and Rigid Borad manufacturer based in shenzhen China.
Yahoo: viivtechavril
SKYPE: viivtech
Mobile: 86)15989403359 ,
Tel: 0086 755-29477736
Fax: 0086 755-29410695
ADD: sha
Jul 13, 2010 | BenQ FP71G 17" LCD Monitor
Trouble with my BenQ monitor
You have LCD panel failing issue or it is not getting the proper voltage to the panel. Look at the power supply and logic board section first for failed caps (leaking/bulging tops). check ribbon cable between the logic bd and the LCD panel. If it is vertical stripes, the the T-CON board, part of LCD panel, then you will need new panel.
Service manuals:
May 14, 2010 | BenQ FP71G 17" LCD Monitor
Thick purple line scrolling up from bottom of screen continually
if it is a uniform pulsating line, then it is the main board or engine. if it is a fuzzy line it is the light tunnel
Apr 26, 2010 | InFocus IN72 Multimedia Projector
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Pink & fuzzy bottom screen
I have a new screen that I will put in it for $24.
Dec 13, 2008 | Nintendo DS Lite Console
BenQ FP71G+ screen blank
If front power led is on and No display ,Problem is with Inverter circuit.The post u descibe should help you determine with certainity that Inverter is the issue.
Apr 08, 2008 | BenQ FP71G 17" LCD Monitor
Benq screen shuts down when pc is plugged in
If it's a 71g and not 71g+ resolder transistors 2sc5707 on invertor board along with grey condensers and inverter transformer.This should solve the problem if it was display shutting off with power led remaining on.Otherwise check power section.
Feb 24, 2008 | BenQ FP71G 17" LCD Monitor
Purple-tinted transparent line
im thinking the set has a bad engine
Dec 18, 2007 | Samsung HL-R5678W 56" Television
BenQ FP71G 17" LCD Monitor Logo
265 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
