Question about Philips PSS110/17 MP3 Player
Blown Fuse How do you find and change the fuse?
  • 8,596 Answers
You would need to unscrew the unit, use a multimeter to test each fuse individually (if it even has fuses), and then take it into a hardware store to find an equaivalent. No one sells the exact fuse individually - not even the manufacturer - so an exact fuse would have to be obtained by buying a working one (which would defeat the purpose of the repair). But, that's how you would do it.
Posted on Mar 23, 2009
How do I change the fuses?
Remove the fuse box cover remove old place new fuse of same size. Step by Step:
  1. Locate your car's fuse panel.
  2. Take off the fuse panel's cover.
  3. Locate the blown fuse.
  4. Remove the broken fuse.
  5. Insert a replacement fuse of the correct amperage-make note of the fuse panel and your owner's manual on this one.
  6. You do keep a few extra fuses of various amperage in your glove box.
How to Find and Replace Blown Fuse in Your Car or Truck
Changing Fuse DMV org
How to Change Vehicle Fuses
How to Change Car Fuse in 8 Easy Steps
May 30, 2016 | Cars & Trucks
I got a malibu 2010 my radio fuse is blown i do not know which box it is in to change it
The radio fuse is in the fuse compartment located on the passenger side of the console. Remove the cover on the console and then remove the fuse box cover, search out the radio fuse and inspect to see if it has blown.
Jul 05, 2014 | 2010 Chevrolet Malibu LS
Change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside
An iron should be calibrated to 410 degrees on wool setting to get the other settings to work correctly.
Dec 26, 2012 | Irons
I have a kia sedona and the injector fuse keeps blowing
how do you change the fuel injectors on a 2002 kia sedona?? the ones im trying to change are underneath the intake....are there fuses for these guys?
Jul 15, 2012 | 2002 Kia Sedona
Taiilights and interior dash lights out on my 97 honda accord..which fuse is it
it may not be a fuse at all, it could possibly be a bad earth or even a blown bulb. It is not uncommon to find multiple bulbs blown at the same time.
Regards
Feb 19, 2012 | 1997 Honda Accord
How do i know if a fuse is blown or not? are there obvious signs or can they seem good when they really are not?
index_008.gif Fuse:
  1. A protection device that opens the circuit, when the fusible element is severed by heat due to over-current passing through.
  2. A part used to join two pieces of metal by bonding them together.
Fuse block:
A box-like enclosure that contains the fuses and circuit breakers for the electrical circuits of a vehicle.
May 02, 2011 | 2003 Chevrolet S-10
Blower not operating
You can check the fuse panel for a blown fuse. Replace blown fuses with the recommended fuse only. Its not safe for your car or you, to switch them to a different size. Be sure that your ignition is in the off position and take the keys out before you change any fuses. If its not a blown fuse, you could have a blown fan motor or faulty wiring but I'd start with the fuse box.
May 09, 2010 | Cars & Trucks
NO INTERNAL LIGHTS FUSE BLOWN, WHICH FUSE IS IT?
Check the power ditribution box under the hood for any Max fuse blown. Check and see if any of the small fuses are blown.
May 24, 2009 | 2007 Ford Five Hundred Limited Sedan
Alternator overvoltaged, car won't start no spark.
Look in the fuse box under the dash for more blown fuse, advise of which ones are blown.
Dec 08, 2008 | 1991 Toyota Camry
Philips PSS110/17 MP3 Player Logo
67 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
