Question about Fisher SLIM-1400 Shelf System
No sound from speaker
The unit turns on ok but no sound come out of the speakers, tried it with headphones but still no sound. Took it to a technician but the part that is damaged does not have a number to order it. Need schematic to order part. Thanks, Luis Santos
  • sleprock Apr 21, 2009
    HAVE SAME PROBLEM BUT NEED TO KNOW WHAT WAS THE COMPONENT YOU FOUND BAD.
    Genius:
  • 1,074 Answers
You can a schematic from www.samsphotofact.com for about $20.00 us
Posted on Mar 10, 2007
SOURCE:
I have a pioneer VSX 920 receiver that thinks i have headphones pluged in. I have no sound from the speakers and when trying to go in speaker related settings it displays: PHONESIN on the receiver. If I...
I think I just fixed a unit with the same problem. I opened the cover and found where the wire from the headphone jack plugs into a board just beside the power supply transformer. When removed, the unit appeared to select speakers as the output. Since the headphones are never used by the owner, I simply left the headphone cable unplugged. Unfortunately, I didn't have speakers to test it with but the unit appeared to be working correctly.
Sep 07, 2011 | Pioneer SX-315
My compaq presario c700 speakers dont give sound however i can listen sound using headphones. Is it some hardware problem in its inbuilt speakers? I have windows 7 ultimate OS.
Hello and Welcome to FixYa!
If you can listen to sound from any other means, as you said via headphones, then the Audio drivers are working ok. The issue is with your Hardware unit; i.e Speakers (The In-built speakers).
I hope you are getting the picture.
Concerned, Nooh
Aug 11, 2011 | Computers & Internet
No sound in headphones
plug in head phones
Go to control panel
go to multifunction sound machine or similiar audio adjuster
if there is an auto detecter click yes ok etc. to turn it on
if not then click headphones under speaker adjustments apply then ok
try then if not try a different pair of head phones some arent pc compatible
or jack could have probs hope this helps
Mar 18, 2010 | Acer Aspire 5720 Notebook
There is no headphone plugged in the tv speakers wont work
Hello
I had the same problem with my computer, where there was no sound because it showed that there was earphones plugged in.
The problem was the the earphone unit on my front USB pannel was a bit worn out, so it shoted out. I just took it to a repair shop and an hour later all was fixed up perfectly for very cheap.You should maybe try it. Please rate if this worked for you.
Best regards
Sep 26, 2009 | Bose Cinemate Digital Home Theater System...
No sound from speakers. Everything else OK.
If headphones work then so does the amplifier. When did this problem start? From what I can find it almost sounds like it thinks you have headphones plugged in, which would disable the speakers.
Apr 24, 2009 | Audio Players & Recorders
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
Low sound in headphone
I would say it is because the unit does not have a built in amplifier. The speakers are powered PC speakers of studio monitors I am guessing. Try plugging the headphones into the headphone jack of the speakers if they have a headphone jack or try a set of powered headphones out of the Edirol and see if it helps.
That should remedy the problem.
Dec 27, 2008 | Edirol UA-4FX External Sound System
Hi...
On some stereo gear the headphone jack interrupts the speaker connection when the headphones are in. you "might" have something broken in the headphone jack which is keeping the speakers from turning on.
Is there a MUTE switch on the unit?
Or an "External speaker off" thingy in the menu?
Sep 07, 2008 | JVC TH-M303 System
No sound
turn your speakers up and moisten your finger. touch the jack plug that inserts into the pc, if you hear the speakers buzz/crackle then they are ok. If not I would try a new lead if possible, else speakers are u/s as if headphones work then speakers should as well as use the same output from the pc, just amplify it unlike headphones. You could also check in the cpanel to see if your speakers are set to speakers and not headphones but to be honest I cant see this stopping the speakers altogether.
Mar 22, 2008 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Maestro 3100
check the audio out port..A faulty port can result in the on board speaker cutting out or muting out. try connectting an external speaker jack into the audio out port and slightly wiggle it.
I do not recommend but open up the unit and check for dry solder at the speaker end
If all ok, it might be a faulty speaker coil. replace with similar impedence
Feb 15, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Fisher SLIM-1400 Shelf System Logo
178 people viewed this question
Top Fisher Audio Players & Recorders Experts
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
