Question about Bose SoundDock Digital Music System for Apple iPod - White
Connection to sound dock for ipod is disconnected
The ipod is not secure on the dock anymore bose sound dock and i get no sound at all. it appears that it is loose and needs to be reconnected somehow. can this be fixed?
  • 1 more comment
  • scottdale3 Dec 11, 2008
    I get no sound on the sound dock unless I take out the plastic adapter and push down and jiggle the iPod. Sucks!
  • Anonymous Dec 27, 2008
    mine is loose also and i can not play my ipod.
  • Adirben02 May 02, 2009
    Dock connector to ipod is loose and doesn't work anymore
  • 17 Answers
See the Bose Sounddock pcb replacement description at http://www.chargeconverter.com/shop/connector.htm?connboser.htm
Posted on Jan 26, 2009
Tip
How to connect an iPod to my Bose Radio
<p>The manufacturer offers two radios Bose iPod connection kit to connect an iPod to the radio. You can purchase the kit to connect the wave or acoustic wave connect kit. Both kits come with a USB audio connection, an iPod dock for iPod, a battery that plugs into the wall and a remote control to use the iPod while in dock. Download all the upgrades to your iPod through Apple's website before connecting a Bose radio. <br /> <p><br /> <p>1. Connect one end of the audio cable is included with the connection kit for iPod "Aux In" on the back of the Bose radio. <br /> <p><br /> <p>2. Connect the other end of the audio cable to the "Audio Out" on the back of the iPod dock. <br /> <p><br /> <p>3. Connect the adapter to an outlet connection kit. Connect the other end of the battery to the "DC Power" on the back of the iPod dock. <br /> <p><br /> <p>4. Set the iPod dock on the right side of the face of Bose radio out. Align the IR sensor on the front of the iPod dock with the IR sensor on the front of the Bose radio. <br /> <p><br /> <p>5. Place the iPod firmly in iPod dock. Point the remote at the IR sensor, iPod dock. Press the "iPod" for the iPod <br />
on Aug 09, 2011 | Apple iPod touch
Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
Jul 11, 2010 | Bose SoundDock Portable Digital Music...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Wont play through my bose system anymore
the apple ipod are very delicate and it seems that docks are very harsh on the internal workings IE: motherboard of the ipod. it not just the touch, it's all ipods.
My suggestion is to check the headphone jack and if you get sound, don;t play your ipod on the dock at all. Your dock has probably done some damage to the audio circuit on the board.
If you get sound through the headphone jack save your ipods life and just use it through the jack.
I have replaced numerous motherboards on ipods played on docks. they just don;t handle the charging and playing very well whether it's heat or just the wrong voltage I am not sure.
But my first question to a customer is have you played it on a dock.
I would stay away from the dock
Apr 30, 2009 | Apple iPod touch
Bose Ipod docking station not working!
Make sure the power supply is connected properly. If the power supply is connected upside down or sideways, the system will make a thumping noise, or will not play at all. However, no damage will be caused by connecting this wire incorrectly.
Mar 29, 2009 | Bose SoundDock digital music system...
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
Sounddock 1 :No sound unless I push down on the iPod
Turn the sound dock over and you will see the connection for the iPod is on a separate piece of plastic, almost looks like it has been bolted onto the main bit. It means a connection will be loose between these two parts in some way. Contact Bose to get this serviced.
Dec 11, 2008 | Bose SoundDock Digital Music System for...
Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Dec 09, 2008 | Bose SoundDock digital music system...
Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Sep 17, 2008 | Bose SoundDock digital music system...
Bose SoundDock Digital Music System for Apple iPod - White Logo
3,084 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
