Have RCA RS -2502 and I push play and all it does is continue to rotate disks I can not get it to play. also it comes on automaticly at 2 pm everyday and will not play
  • zoglman Dec 06, 2008
    it will go all daand not play
  • zoglman Dec 07, 2008
    tell me how to clean the lens.
    Brigadier General:
  • 6,966 Answers
Hi and welcome back to FixYa,
Based on your description, you have two (2) concerns:
  • timer - apparently timer is set to turn on at 2:00PM. If you still have the original remote, try disabling TIMER SET or see if can be done on the front panel. Alternately unplug from the mains for a couople of hours to reset and revert to factory defaults. Of course all user setting, configurations and memory would be erased;
  • spins but not play - could indicate a dirty or weak laser eye. Cleaning could be performed using a CD ROM disc cleaner. While the lens is replaceable, repair cost consideration would have to be factored in based on the age of the unit. At some point, it may be cheaper to hookup an external CD player to the AUX input.
Good luck and Thank you for using FixYa.
Posted on Dec 06, 2008
  • 4,472 Answers
Being that the system is rather on the the old side. It is not worth to have the unit serviced. I would replace the unit with a similar unit. A better unit could easily be purchased for under a 100$. Please take a moment to accept and rate my solution.
Thanks,
Lee
    Sergeant:
  • 399 Answers
The lens which reads the discs is either faulty or dirty.either needs cleaning or replacement.
The auto mode isn't working on my zilla digital 24-7 power center, when on auto mode no lights come on?
Copy following link to identify timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Is this a new timer??? Or old timer that stopped working?
Replace battery.
Press reset button to clear all memory traces before programming.
Check programming for overlaps and mismatched day(s) of operation.
Test outlet for correct polarity and grounding using circuit analyzer.
Make sure light bulb is turned ON. Timers do not reach out and rotate on-off switch.
Make sure outlet has at least 80% rated voltage shown on load label. For example 115 volts x 80% = 92 volts
About your specific programming needs:
Zilla selects 12 o'clock as changeover time between am-pm.
So if you want 8:02 to 7:59 operation, then that is under the 12 hours, but it crosses the 12 o'clock am-pm changeover.
Workaround: Shorten your times to less than 12 hours just like you have done.
But set current time differently so 8-8 falls under either am or pm, but does not cross am-pm. The timer does not actually know what the current time is, so simply fudge by amount needed.
Nov 18, 2012 | RTO Zilla 24/7 Digital Timer Power Center
I dont know how many watts it is
4 Ohm Stereo Power (RMS): 250W X 2
4 Ohm Mono Power (RMS): 850W X 1
2 Ohm Stereo Power (RMS): 450W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Length: 16.93"
Width: 11.66"
Height: 2.37"
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Dec 23, 2010 | Concept CC-2502 Car Audio Amplifier
I have a intermatic ej351c indoor wall switch programmable timer that I have tried several time to program an on time for the lights to come on however the lights does come on. I have followed the...
There might be a couple things that are easy to overlook.
Press the button to see if lights come on >>> if light do not turn on with manual override, then light might be burned out or circuit breaker tripped. Sometimes a breaker is tripped but you can't tell by looking at it
1) The timer is used on incandescent bulbs only. I don't know why, but it says no
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
2) Is the red indicator light ON?
For programs to work, timer has to be in automatic mode and the red indicator light will be ON
The Switch Timer can be used in two modes. manual & automatic
To switch between modes, quickly press the dial twice:
AUTOMATIC MODE: The Switch Timer will turn your lights ON or OFF according to programmed settings. The RED indicator light stays ON when in Automatic Mode.
MANUAL MODE: Programmed settings are inactive, and
the Switch Timer will only turn the light ON or OFF when
you push on the dial.
RED indicator light stays OFF when in Manual mode.
3) setting current time> lets look at the red indicator light while doing this
Move switch lever to OFF-Clear
Move lever to ON >>> red indicator is flashing
Rotate dial to nearest current time (if it's 7:20 pm, rotate dial to 7:30pm)
Press the dial once to set current time > red indicator light goes off
Do not accidentally press dial or it will set the wrong time....ok we know that
4) overlapping programs/
Make a chart of the times you want to program with ON and OFF plus am & pm
Check your chart for overlapping times that tell the timer to do more than one thing
Rotate dial clockwise to the first ON time >> pay attention to am & pm
Press button and first ON time is set
Rotate dial clockwise to the first OFF time >> watch the am and pm
Press button and first OFF time is set
You can have 48 on-off times >>> which seems a lot for a 24 hour repeat timer
5) try the timer with one program
6) If timer still doesn't work, put switch back in and see if lights turn on that way >>> it could be a loose wire suddenly cropped up
Last step >>> timer is no good, you need another one. We tried.
Oct 16, 2010 | Electrical Supplies
I am using Nokia N72 phone with Airtel sim.this week there are number of outgoing calls automatically dialed from my mobile.the numbers are +37127690056(for 3:59 min)+263912794857+359999763254e.t.c.om 30...
It seems that your phone is infected with malwares so u format your phone. the process is press *3, calling button & power button simultaneously until you not see the nokia connecting logo on your screen.
Jun 16, 2010 | Nokia N72 Cellular Phone
When i push play on either deck - the tape starts to move and then the tape deck switches the tape's direction continually
If you observe the sprockets in the cassette you'll probably see they're not turning. That would indicate a broken belt or something mechanically common to both decks. Deck logic probably interprets the lack of sprocket rotation as end of side and auto-reverses. Take it to a shop.
Mar 19, 2010 | Technics RS-TR272 Single Cassette Deck
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Rca rs 2620 power but no audio
I need to see if the manual has any method of button pushing to get the sound back on. Otherwise, I am not an electronic type of guy that has soldering tools, can tell a resistor from a plug, etc. if that is what is needed to get the thing going with sound.
Dec 14, 2008 | Audio Players & Recorders
19 people viewed this question
 Grubhead
Grubhead
