Question about Canon CLC 1120 Color Copier
Canon 1120 i have an error code whick is 0105
I want into the control an clear out them but it show
fix web-2000
pri-cln 2000
p-roller 1000
  • designs504 Dec 07, 2008
    so how can i put the new vaule in the mentioned parts
  • luis_and_60 Jan 09, 2009
    I can not communicate with the printer to my computer ...
    diagnostic tests interpreted as the network port.
    Help me plis....
  • 76 Answers
Hi you must reset the counter in service mode *2,8* counter and put new value on mentioned parts
Posted on Dec 07, 2008
  • Fernan
    Fernan Dec 08, 2008
    hi when u select the counter of the part,just press clear and you will see the new value will be reset to 00000
Ir5000 error code 000005-000 how do i clear it
Whenever you have replaced the fixing web, be sure to set '0' to
the following in service mode:
COPIER>COUNTER>MISC>FIX-WEB
COPIER>COUNTER>DRBL-1>FIX-WEB.
do not clear the limit,
Jan 16, 2014 | Canon imageRUNNER 5000 Copier
Cano CLC 1120 error E004 0203 E072 0203 the machine turns on and off the merger does not light not heat MOTHERBOARD TESTED OK, FUSION SYSTEM TESTED OK, TRANSFER SYSTEM TESTED OK, WHAT SHOULD SPARE CHANGE...
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermistor. Hope this helps...please post back for further assistance.
Daniel
Mar 03, 2011 | Canon CLC 1120 Color Copier
My canon 1180 is E000 0105 error code. please help me
that error is from fixing unit try to reset that error to reset that error press * 2&8 * then select copier then select function then press clear then select erro then press ok then turn off/on the power switch
Dec 09, 2010 | Canon CLC 1180 Copier
Ir 405 copier code as displayed e005. but what is problem i am changed web roller but still e005
Hi
Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps... Daniel
Sep 30, 2010 | Canon imageRUNNER 400S Copier
Error code E000 and 0105 under
its problem power supply please repear it near by a good technician who repear it
Nov 21, 2009 | Canon CLC 1000 Color Copier
How do i reser error code e005 0100
How to clear fixing web counter after replacement of fixing web roller: E005 Error Code
[ Case in the field ] Field Remedy
Execute the following service mode items.
1. COPIER > COUNTER > MISC > FIX-WEB
2. COPIER > COUNTER > DRBL-1 > FX-WEB
Sep 04, 2009 | Canon CLC 1180 Copier
My canon read error e000 105
go into service mode -function-clear-error- take machine off -un plug from wall -reconnect- turn machine
Dec 05, 2008 | Canon CLC 1120 Color Copier
CLC 800S E0005
remove your cleaning web then relese it by goimg into service mode -function -clear-error then cut machine off then on
Sep 23, 2008 | Canon CLC 1120 Color Copier
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
Canon CLC 1120 Color Copier Logo
105 people viewed this question
old marine
old marine
