Question about Sony Handycam DCR-DVD403 DVD Camcorder
My Camcorder switches it'self off
Okay well i got my camcorder back from sony today from having the automatic lens cover not opening. And now a whole new problem happens; when i twist the switch to turn on my camcorder, after a few seconds, it makes the starting up noise it makes and the lens opens etc, but then almost as soon as i can see the LED screen light up it just switches itself off.
it is not the battery which is causing this, it was almost fully charged, and i have tried it plugged into it's charger
please help!
  • 1,199 Answers
You will need to send it back to sony explain the new problem arose after they fixed the first problem they will fix it free of charge even if there is no warrenty
Posted on Dec 06, 2008
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Lens Cover not fully open
It sounds like a problem with the firmware in the camcorder itself. As an authorized Sony repair person, I have gotten no technical bulletin on this model. The firmware is preloaded into the microprocessor IC. You will need to have this unit looked at by an authorized Sony repair center who specializes in camcorder repairs or send the unit to a Sony factory service center. good Luck
May 22, 2007 | Sony Handycam HDR-HC1E HDV Digital...
HELLO My camera zoom to self AUTOMATIC
Usually, it’s a faulty zoom switch inside the camera's lens grip.
Feb 15, 2010 | Sony Dvcam DSR-250 Camcorder
Hi I have DRC-SR200 camcoder, bought one year ago. Issue is lens cover is not opening. On the LCD display there is a message "lens cover not fully open. Turn off and on". I tried that but no use. Went...
Hi, perform the following steps to get this issue resolvbed... 1. Check whether the lens cover is opened 2. check whether the battery is fully charged. If the battery is not fullly charged, connect the Camcorder to the wall outlet using the sipplied AC adaptor. 3. Then, try resetting the Camcorder by pressing the RESET button using a sharp-pointed object while the Camcorder is turned ON. 4. If the issue still persists, turn OFF the Camcorder; then remove the battery pack and discinnect the Ac adaptor from the Camcorder; slide the POWER switch to the ON position for 1 minute. Then, connect the AC Adaptor tro the wall outlet and cjeck whether it helps.
If the issue still persists, service of the unit may require. contact the manufacturer of the Camcorder to get ut serviced.
Jul 10, 2009 | Sony Handycam HDR-HC1E HDV Digital...
"Remove Camera Lens Cover"
It seems bad ccd imager problem in Sony DCR-HC30E camcorder and ccd imager will be replaced.
Sony will replaced ccd imager free of cost as per announced scheme.
Click Sony CCD Imager Support UK for details.
Apr 11, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
Sony DCR-DVD403 camcorder - picture won't focus. E:61:10 error.
E61:10 is a lens error code. You have a bad lens unit, but sometimes they can be fixed. The focus and zoom motor worm drives on the zoom lens jam when they get dropped. If your really really carfull you can free them up and fix the lens. Thereis a plastic claw that rides along the worm drive shaft that can get jamed. I've fixed thousands of these but i'm a guru. It can be tricky.
Dec 09, 2008 | Sony Handycam DCR-DVD403 DVD Camcorder
Camera Lens Cover won't open
Since Sony will not sell parts you have 2 choices here, replace the camera or send it in to Sony for repair.
Apr 17, 2017 | Sony Handycam DCR-DVD403 DVD Camcorder
DCR-HC96 Automatic Lens Cover won't open
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 22, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
Sony DCR-DVD653E
Hello, in order to cure the above problem you should replace the lens barrier part number: 178723611. Please note that this intervention is complex and requires a professional help (Authorized Sony Service). Best regards, Arpi
Apr 07, 2007 | Sony DCR-DVD653E DVD Camcorder
Lens Cover
The micro motor broke in the dust cover that opens and closes the cover. If your camcorder is still operational then I would not worry too much. Only when you can not get pass the error messages to operate then you will need to get a new one from sony (~$50). If you are mecahnically sound to take apart small things otherwise, take it to a professional.
Aug 22, 2006 | Sony Handycam DCR-DVD203 DVD Camcorder
Sony Handycam DCR-DVD403 DVD Camcorder Logo
50 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
