Question about Sony Cyber-Shot DSC-M1 Digital Camera
Flash burst My flash unit on Sony M1 was burst. How can I replace the bulb/flash unit?
  • Anonymous Jan 24, 2008
    It will cost about $ US 80 and 10 minutes.
  • cynt1980 Mar 10, 2008
    My flash is gone on my DSCM1 camera .. not sure if it burst or not. but I can no longer take pics in the night time or in dark rooms. What can I do??? Is it expensive????
    Sergeant:
    Champion:
  • 326 Answers
Atempt to open this camera if you are not specialized for this job is not a good idea. Part number for the flash unit 147904011. Price around 50 Euro (for my account). If you need more info, please advice. Arpi
Posted on Mar 17, 2007
SOURCE:
Nikon SB-700 bulb filament burst. Not working anymore..
Yes it is repairable. Take it to a camera store or go on Nikon's website and get the details on how to get a repair from them.
Jan 23, 2014 | Nikon Cameras
How do you replace the flash bulb in sony cyber-shot dsc h10 camera?
You must send the camera in for repair to replace the flashing unit
Jan 23, 2012 | Sony Cyber-shot DSC-H10/B Digital Camera
I cannot find the burst mode on my camera, the only thing that my camera said was cannot use burst mode with flash
In burst mode, the Camera will be taking multiple images. Flash can only spark once to get enough light. If the Flash is enabling in the multi burst mode, it will loose the battery power as well as not give the correct images. Hence, by default regardless of manufacturer, the flash cannot be used in multi burst mode.
I hope you understand my concern. Thanks.
Jan 24, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My flash bulb is broken? where will i go to have it changed/repaired?
The part No with description is give below:
1-479-040-11 FLASH UNIT (FL80000)
To get this part please see the link below:
http://www.partstore.com/Part/Sony/Sony/147904011/New.aspx?SearchTerm=True
Thanks for using fixya.
Nov 17, 2009 | Sony Cyber-Shot DSC-M1 Digital Camera
Flash bulb not fuctioning my camera sony cyber shot dsc w55
1.Try initializing the Camera.To initialize the Camera, select the "Initialize" option under the "Setup 1" Menu of the Camera.
2.Even if the flash is set to always ON, the flash will still not work in the following circumstances:
* When shooting MPEG movies.
* When shooting in the Twilight or Handheld Twilight mode.
* If shooting with the Burst or Multi Burst mode.
* Shooting with Sweep Panorama.
* Shooting with the Fireworks or High Sensitivity mode.
* If an external flash is connected.
Refer:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C95364
Oct 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Flash flickers...
i honestly never came across anyone who had a flash replaced usually because most companys flat rate out of warranty repairs at 100-125 dollars-if it's a p series camera it sounds like the flash is dying or the battery is worn out and not supplying proper voltage to allow it to fully fire-i would consider buying a new w series w150 is great or 120- if battery is fine then flash is just shot-even old memory sticks won't work in new models so you also have to buy a new card
Jul 27, 2008 | Cameras
Flash not working?
I found this solution on another site and it worked for me. Good luck!
hi - thanks - you're right. I called SONY
last week. They told me to reset, as you describe. here's also what I discovered - the flash locks you out in Burst (fast frame) mode. The flash can't recover that fast. Out of Burst mode, you can control the Flash. Isn't it a much better camera with the flash?
Enjoy your W80! Thanks, Jim Connecticut, USA
Jul 17, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Flash stoped working
Make sure yor flash is turned on. You might have burnt out flash bulbs.
Apr 16, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Flash not working
I had the same problem with my flash not working on any setting, but I found a way to fix it: hit the menu button, make sure the "rec mode" choice is set to normal instead of burst. I think the burst mode takes multiple shots in a row, so the flash isn't compatible with that setting?
Feb 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cyber-Shot DSC-M1 Digital Camera Logo
89 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
